Author Topic: TrueColor dialog  (Read 2590 times)
Jürg Menzi
  • Oberegg, Switzerland
TrueColor dialog
« on: May 24, 2006, 11:14:48 AM »
Does somebody know how to call the TrueColor dialog from VBA, like 'acad_truecolordlg' in LISP?
I know there is an API for the ACI color dialog, but can't find something similar for TrueColor.
A2k7...
TIA
Jürg
A computer's human touch is its unscrupulousness!
MENZI ENGINEERING GmbH
Current A2k16... A2k24 - Start R2.18
fxcastil
Re: TrueColor dialog
« Reply #1 on: May 27, 2006, 04:18:01 PM »
Here are the 3 ways I know about
Option Explicit
Public Declare Function acedSetColorDialog Lib "acad.exe" (color As Long, ByVal bAllowMetaColor As Boolean, ByVal nCurLayerColor As Long) As Boolean
Sub test()
  Dim lngInitClr As Long
  Dim blnMetaColor As Boolean
  Dim lngCurClr As Long
  On Error Resume Next
    If acedSetColorDialog(lngInitClr, blnMetaColor, lngCurClr) Then
       MsgBox lngInitClr
   End If
End Sub
Public Function ColorDialog() As Integer
Dim intVariable As Integer
If Connect Then
objAcad.Application.WindowState = acMin
'calls the acad color dialog and returns
'the index of the color selected or -1 if cancelled
'store current sysvar value
intVariable = ThisDrawing1.GetVariable("USERI5")
'call color dialog
ThisDrawing1.SendCommand ("(setq clr (acad_colordlg 1))" & vbCr)
ThisDrawing1.SendCommand ("(if (= clr nil)" & _
"(setvar ""USERI5"" -1)" & _
"(setvar ""USERI5"" clr))" & vbCr)
ColorDialog = ThisDrawing1.GetVariable("USERI5")
'reset sysvar
ThisDrawing1.SetVariable "USERI5", intVariable
End If
Fred Castillo
Jürg Menzi
« Reply #2 on: May 29, 2006, 02:29:10 AM »
Thank you Fred...
I have not a problem with calling the ACI color dialog from AutoCAD's VBA, rather with calling the TrueColor dialog in A2k4+.
And the third way?... :-)
Cheers
Jürg Menzi
« Reply #4 on: May 29, 2006, 11:39:29 AM »
I will give those a try, thanks Fred.
