Author Topic: Lost Style Purging capabilties in vba?  (Read 4434 times)
Matersammichman
« on: May 23, 2006, 02:28:55 PM »
What happened to the ability to purge the following in vba?
RoofSlabStyles
SlabStyles
CurtainWallStyles
CurtainWallUnitStyles
WindowAssemblyStyles
I could purge them fairly easily via vba in ADT2002, but can't in 2005.
What gives?
David Hall
  • Automatic Duh Generator
Re: Lost Style Purging capabilties in vba?
« Reply #1 on: May 23, 2006, 05:16:17 PM »
what code are you using to purge?
ThisDrawing.PurgeAll
Matersammichman
« Reply #2 on: May 23, 2006, 05:31:05 PM »
That's just for regular CAD purging.
What I'm referring to is Styles (ADT).
David Hall
« Reply #3 on: May 23, 2006, 05:48:36 PM »
I dont have ADT, so I dont know off the top of my head.
David Hall
« Reply #4 on: May 24, 2006, 07:08:53 PM »
chirp
Bob Wahr
« Reply #5 on: May 24, 2006, 07:21:53 PM »
I don't have ADT so I don't get to play along from home but you might look at something like
dim objRoofSlabs as RoofSlabStyles
dim objRoofSlab as RoofSlabStyle
on error goto ka_blooie
set objroofslabs = thisdrawing.roofslabstyles
For each objroofslab in objroofslabs
  objroofslab.delete 'hopefully if the style is used it will toss a binky or whatever Kerry says
next objroofslab
arvyderchy:
  Exit Sub
ka_blooie:
  err.clear
  resume next objroofslab
end sub
This is really rudimentary, really basic, and guaranteed NOT to work as is and is intended merely as a suggestion on one way that it might be possible to go about it.
David Hall
« Reply #6 on: May 24, 2006, 07:25:18 PM »
Spit the dummy is what your looking for. but toss the binky was funny as hell
Bob Wahr
« Reply #7 on: May 24, 2006, 07:30:03 PM »
yeah, I knew it was something like that, I just couldn't come up with it, thanks.
« Reply #8 on: May 24, 2006, 07:40:57 PM »
:lmao:
- John Carmack
- J.R.R. Tolkien
« Reply #9 on: May 24, 2006, 09:14:31 PM »
heheheeh
I use a 'SpitTheDummy' method ..
but 'ka_blooie:' sounds pretty descriptive ..   : - )
David Hall
« Reply #10 on: May 25, 2006, 12:41:07 PM »
this is so funny, Im now using
ed.WriteMessage("AutoCAD has Tossed the Binky  ");as my error checking line
