Author Topic: Area reactor  (Read 34352 times)
MvdP
Re: Area reactor
« Reply #75 on: June 30, 2006, 01:26:10 PM »
I have another question. which i think is almost an mission impossible.
When browsing through my drop downlist i want when i am on a certain area-name the hatch button immediately  to be greyed out. Is this possible..?
Re: Area reactor
« Reply #76 on: June 30, 2006, 01:54:00 PM »
You can do that.  Set up an action tile for the list, and have it check the value (off the top of my head, $reason) and if it's the one, then mode tile the hatch button (I would set it to not hatch also, and mode tile it out).  I don't have time to show you code, but this is the way.  Hope I wrote it clear.
MvdP
Re: Area reactor
« Reply #77 on: June 30, 2006, 03:17:25 PM »
This is what i understand ( i think).
Your suggestion is that the default hatch button is always greyed out,and this toggle button will be available when i immediately  choose another  area-name in the drop down list which will unlock the toggel button,This is a though one so the question is how (when you got the time) to do this.
Re: Area reactor
« Reply #78 on: June 30, 2006, 04:03:17 PM »
Here is a small example to show you what I'm talking about.  Here is the lisp portion.
(defun c:Testing (/ tmpList DiaLoad)
(setq tmpList '("test" "test1" "Grey Out"))
(setq DiaLoad (load_dialog "Test.dcl"))
(if (not (new_dialog "Testing" DiaLoad))
 (exit)
(start_list "LsBox" 3)
(mapcar 'add_list tmpList)
(end_list)
(action_tile "LsBox" "(if (= (atoi $value) (vl-position \"Grey Out\" tmpList)) (mode_tile \"Tog\" 1) (mode_tile \"Tog\" 0))")
(action_tile "accept" " (done_dialog 1)")
(start_dialog)
Here is the dcl portion, save as "Test.dcl".
Testing : dialog { label = "Testing grey out" ;
: boxed_row {
 : list_box { key = "LsBox" ; }
 : toggle { key = "Tog" ;}
: row {
 : button { label = "Done" ; key = "accept" ; is_cancel = true ; }
MvdP
Re: Area reactor
« Reply #79 on: July 10, 2006, 02:24:37 AM »
Unexpectedly i had a week off.
It works great, so thanks again Tim,, but how to add one more to grey-out list.
This aint the the way i found out.
(vl-position \"Grey Out\" \"test\" tmpList))
Re: Area reactor
« Reply #80 on: July 10, 2006, 11:16:50 AM »
You would have to use an or statement.  Something like.
 (or
  (= (atoi $value) (vl-position \"test\" tmpList))
And you're welcome.
MvdP
Re: Area reactor
« Reply #81 on: July 11, 2006, 02:03:06 AM »
Thanks Tim you're a lifesaver.
Re: Area reactor
« Reply #82 on: July 11, 2006, 11:04:06 AM »
You're welcome.
MvdP
Re: Area reactor
« Reply #83 on: July 12, 2006, 02:22:23 AM »
To add more candy i added an image (for a slide) in the dcl and i immediately want the slide to change when browsing through my areaname drop downlist.
So when arename is toilet  i want it to show slide1
and when arename is bathroom i want it to show slide2 and so on..
How can this be done.?
Re: Area reactor
« Reply #84 on: July 12, 2006, 11:13:52 AM »
Don't know.  I have never used slides for a dcl.  Maybe it is time to start a new thread with request for help on this subject.
GDF
Re: Area reactor
« Reply #85 on: July 12, 2006, 11:32:35 AM »
I have modified the following routine to do this. Reads a text file listing the slide name. Then it places the slide from the slide library
as selected from the list box. There are many ways to do this, but I have found Lintang's to be the best.
Original routine "HotBlocks" by Lintang Darudjati.
Gary
MvdP
Re: Area reactor
« Reply #86 on: July 12, 2006, 11:50:32 AM »
[/quote]
But thanks anyway and for all the help and leasons.
And Gary i will check your suggestion.
