Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Question about Layer property - "Current VP Freeze"
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Question about Layer property - "Current VP Freeze" (Read 2719 times)
FengK
Guest
on:
May 19, 2006, 03:54:11 AM »
Where is information stored? I could not find it either in dxf or vba reference.
The "New VP Freeze" seems to be this property: ViewportDefault.
Thanks for help.
Kelie
Logged
CADmium
Newt
Re: Question about Layer property - "Current VP Freeze"
Reply #1 on:
May 19, 2006, 05:56:09 AM »
The frozen Layers are stored on the viewport-object..
use (entget(car(entsel))'("ACAD")) and select a viewport and have a look of the XDATA
Logged
"Bei 99% aller Probleme ist die umfassende Beschreibung des Problems bereits mehr als die Hälfte der Lösung desselben."
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Reply #2 on:
May 19, 2006, 06:54:18 AM »
Jimmy will get you started ... and then some
http://jtbworld.com/lisp/vplayers.htm
Logged
Global Moderator
Seagull
Reply #3 on:
May 19, 2006, 07:40:56 AM »
And one from MP.
http://www.theswamp.org/index.php?topic=4002.msg47810#msg47810
Logged
FengK
Guest
Reply #4 on:
May 20, 2006, 06:12:52 PM »
Thanks guys. I should have thought of that. So for a particur layer, if the current vp changes, this property may change as well. Correct?
Logged
sinc
Guest
Reply #5 on:
May 20, 2006, 07:58:22 PM »
That's the whole idea of the "Current VP Freeze" functionality - you can freeze a particular layer in a particular viewport, while leaving it thawed in others.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
