Author Topic: mdt 5  (Read 2778 times)
malcolm
mdt 5
« on: March 03, 2004, 11:01:52 AM »
i've created a pipe using a 3d spline but in several of the drawing views the pipe outline has disappeared.
any ideas?
Spageddie
mdt 5
« Reply #1 on: March 03, 2004, 04:26:11 PM »
8)  Check the response on the cadalyst site.
malc
mdt 5
« Reply #2 on: March 04, 2004, 10:25:32 AM »
Hello again guys
Have had no luck on the cadalyst site (god that is so slow)
I'm still in trouble, I have a large assembly in MDT5, the drg views are all correct but some of the pipes in some of the views are not shown, it's not layers or hide or anything silly, it's purely random. It must be either a system setting or else MDT5 does not like pipes created by 3d splines.
Is there a smillie for desperate?
Spageddie
mdt 5
« Reply #3 on: March 04, 2004, 05:50:30 PM »
8) You say this random...so does that mean that pipe that look ok now will sometime dissappear completely/partly ?
malc
mdt 5
« Reply #4 on: March 05, 2004, 03:02:14 AM »
thanks spageddie
I believe the problem is with mdt itself, when you create a new view in a layout, if there are complicated curves, mdt will struggle to translate them.
I've noticed this on iso views, quite often there will be lines missing.
So my meandering pipe paths are just causing a problem for mdt to translate.
This only happens when you create views with hidden lines of course.
Thanks everyone
Spageddie
mdt 5
« Reply #5 on: March 07, 2004, 08:31:18 PM »
:? Hmmmm.....what a bugger.......
I wonder if machine/video related ???....I'll see what I can find for you...
