Author Topic: acedFindFile  (Read 5920 times)
Bobby C. Jones
  • Cry havoc and let loose the dogs of war.
acedFindFile
« on: May 10, 2006, 11:25:28 AM »
Modified: Added using Directives.
It's been slow around here lately!
As I'm using the 2007 version of the managed API I'm noticing that they are including more and more of the ARX API with each release.  However here's one that they haven't got around to exposing yet.  The error message is long enough to verge on excess, but at least you won't have any questions if it's thrown :-)
Anybody else have any interesting API shortfall workarounds?
using System;
using System.Text;
using System.Runtime.InteropServices;
namespace GratuitousNameExposure.BobbyCJones
  public sealed class AcadFileUtilities
    private const int maxResultLength = 511;
    [DllImport("acad.exe", CharSet=CharSet.Auto, CallingConvention=CallingConvention.Cdecl)]
    private static extern int acedFindFile(string fileName, StringBuilder result);
    private AcadFileUtilities() { }
    public static string FindFile(string fileName)
      StringBuilder fullyQualifiedFileName = new StringBuilder(maxResultLength);
      acedFindFile(fileName, fullyQualifiedFileName);
      if (fullyQualifiedFileName.Length > 0)
        return fullyQualifiedFileName.ToString();
      else
        throw new System.IO.FileNotFoundException("File not found in the current directory, the current drawing file directory, the AutoCAD search path, in the AutoCAD installation directory, or in the specified location (if it was specified).", fileName);
« Last Edit: May 10, 2006, 11:56:57 AM by Bobby C. Jones »
Bobby C. Jones
Draftek
Re: acedFindFile
« Reply #1 on: May 10, 2006, 11:54:54 AM »
That's really cool Bobby.
I have done similar in vb using the Declare statement, but hadn't considered importing arx dll's in c#.
Bobby C. Jones
Re: acedFindFile
« Reply #2 on: May 10, 2006, 02:13:17 PM »
De nada.
Well, it is cool which is much more than nada.  What I meant was that I did nada :-)
There are lots of examples of importing ARX functions in .NET on this forum and others.  This is just one that I needed today and thought that I would share and try to drum up some conversations.  And dig to see if there are others out there that wanted to share some code that I could steal ;-)
Bobby C. Jones
Draftek
Re: acedFindFile
« Reply #3 on: May 10, 2006, 02:35:43 PM »
ack! GOT to get our more often.
I don't have anything worth stealing yet. All inside the box stuff.
jmaeding
Re: acedFindFile
« Reply #4 on: May 16, 2006, 01:24:43 PM »
It seems you can do anything by importing ARX functions.
Can someone do one that does what GRDRAW does in lisp?  I need it BAD.
Is there a technical limit to this importing?  like, what categories of ARX classes would it not work on?
James Maeding
Bobby C. Jones
Re: acedFindFile
« Reply #5 on: May 16, 2006, 05:09:12 PM »
Hey James,
What version of acad are you using?  The 2007 Editor class has a DrawVector() and a DrawVectors() method.  I haven't used either of them.
In 2006 and 2007 you could use a Jig.  The arx sdk has examples.
And if needed, I suppose that you could use p/invoke to call acedGrDraw() or acedGrVecs() in 2006.
Bobby C. Jones
Alexander Rivilis
  • Programmer from Kyiv (Ukraine)
Re: acedFindFile
« Reply #6 on: May 20, 2006, 05:57:29 PM »
    private static extern int acedGrDraw(double [] from, double[] to, Int32 col, Int32 hl);
    [CommandMethod("GrDraw")]
    static public void GrDraw()
      double[] from = {0,0,0};
      double[] to = {10,10,0};
      acedGrDraw(from,to,1,0);
jmaeding
Re: acedFindFile
« Reply #7 on: May 25, 2006, 03:52:07 PM »
que bueno!  finding goodies here more and more, thanks
James Maeding
