Author Topic: Paste special issue  (Read 3107 times)
Martin-Y
Paste special issue
« on: March 03, 2004, 07:14:11 AM »
Help, what am I missing.
Copy and paste from excel, has always worked. I use paste special/product entities.
Now nothing appears. I have rebooted, started new drawing, changed background colour, changed layer from 0 to specific. Only 47 lines in excel.
Been using ADT3.3 on XP Pro with Excel 2002 for about 2 years never happened before.
Am I being totally stupid and missing something obvious (nearly 50 !!)
Martin-Y
Paste special issue
« Reply #1 on: March 03, 2004, 07:27:20 AM »
Well, I hadn't tried copy and paste of half the spreadsheet but that works.
computers........what are we going to do, sometimes I miss the board but it doesn't last.
Martin-Y
Paste special issue
« Reply #2 on: March 03, 2004, 07:29:41 AM »
And the other half....
Actually I could say it makes a change talking to yourself, trouble is I'd be lying, age thing again.
Paste special issue
« Reply #3 on: March 03, 2004, 07:39:30 AM »
Are you pasting the cell contents OR the sheet itself?
If it is the sheet itself, try inserting an ole object from the file.
If you are trying to insert the cell contents, you might be picking up a formula instead of the text, either way though it would seem that something would show!
Martin-Y
Paste special issue
« Reply #4 on: March 03, 2004, 08:07:04 AM »
Cell contents not formula. Funny thing is that even with big files it still pastes something. Must be part of the issue Acad has with large clipboard data.
That's the wednesday puzzler, it is wednesday isn't it
Dommy2Hotty
Paste special issue
« Reply #5 on: March 03, 2004, 09:14:43 AM »
I always highlight the cells needed, edit->copy, then with Excel still open, go into the AutoCAD drawing, edit->paste special, select the second radio button (for link) and hit ok.  Then use OLESCALE to scale it to the right size...hope that helps...
