Author Topic: CHALLENGE: Individual attribute edit like DDEDIT  (Read 17249 times)
nivuahc
Re: CHALLENGE: Individual attribute edit like DDEDIT
« Reply #15 on: May 10, 2006, 08:36:43 AM »
doh!
nivuahc
« Reply #16 on: May 10, 2006, 08:44:34 AM »
Whoa! I just tried out the latest and clicked the ESC button on my mouse...
; entering keyboard break loop
AutoCAD has become completely unresponsive....
EDIT:
VLisp highlights the following for me:
(vl-catch-all-apply
               '(lambda ( )
                    (setq
                        data nil
                        data (grread t 13 2)
nivuahc
« Reply #17 on: May 10, 2006, 08:46:55 AM »
Well closing VLisp resets the break loop... what'd I do wrong?
« Reply #18 on: May 10, 2006, 09:17:19 AM »
You have the vlisp options to break on all errors.
« Reply #19 on: May 10, 2006, 09:20:10 AM »
Cool routine MP :). Hey chuck...you're not crazy. I'm seeing choppiness when the routine is runnning and it's not that my machine is slow.
Ron
« Reply #20 on: May 10, 2006, 10:03:17 AM »
Hmmm, I can't explain the choppiness -- I've run it on 2 different PCs, 2 different versions of AutoCAD, with and without a glut of attribute laden blocks -- runs fine. <scratchin' nuggin>.
PS: Did another edit -- dumped the edit box label -- it was just chewing up real estate.
<old image may be in your cache so you may need to do a refresh>
Sdoman
« Reply #21 on: May 10, 2006, 03:08:47 PM »
I like that EditAttrib routine! Thanks MP!
I tested your routine on a drawing that contains lots of blocks with lots of attributes.  Performed better then the native Attedit command.  Quick and light.
I also tried a couple other routines posted, all of them are very worthy routines.  What a great place this Swamp is.
« Reply #22 on: May 10, 2006, 06:01:07 PM »
Hey MP,
How hard would it be to make the routine have a shift selection to select multiple attributes and change them all at once?
Ron
« Reply #23 on: May 10, 2006, 06:38:06 PM »
Hey MP,
Ron
Wouldn't be hard, but would be a different code variant -- grread does not provide the ability to recognize the state of the shift key. A variant that achieves what you're implying might be as follows --
Go into a polling loop -- as long as the user selects (hilites) attributes (clicking them again would would de-select / de-hilite them) the program would collect them. If the user presssed [enter] and any attributes were collected they'd then be displayed for editing, say 8 to a screen, otherwise the program would terminate.
FengK
« Reply #24 on: May 10, 2006, 06:52:02 PM »
Edit 1: Added hililiting when cursor is over a valid attribute entity.
Edit 2: Commented code a bit for others.
Edit 3: Added a little screen grab for fun.
Edit 4: Dumped the edit box label.
Nice job Michael.  Can I ask what software you used for the screen recording?
« Reply #25 on: May 10, 2006, 08:52:14 PM »
Thanks Kelie, I used Camtasia Studio, about $300 and worth every penny in my estimation.
FengK
« Reply #26 on: May 12, 2006, 02:56:09 AM »
i was thinking something like this should work too.
prompt user to pick entity (nentsel, nentselp);
extract old string;
create a temporary text object with that string;
issue DDEDIT command and ask user to modify the temporary text;
put the new string from the text object to the originally picked entity;
delete the temporary text object.
just an idea. not implemented.
« Reply #27 on: May 12, 2006, 11:49:00 AM »
extract old string;
Guess you didn't look at my code. :-)
http://www.theswamp.org/index.php?topic=10028.msg128482#msg128482
« Reply #28 on: May 12, 2006, 11:53:53 AM »
extract old string;
Or mine just a couple posts:
http://www.theswamp.org/index.php?topic=10028.msg128438#msg128438
Only I used the default edit box instead of the ddedit one and I didn't duplicate the item as text .. I figured why bother .. if you can read the test, then just edit it.
FengK
« Reply #29 on: May 13, 2006, 04:11:15 AM »
Sorry, CAB and Keith.  As you guys guessed, I didn't read the code from you.
