Author Topic: Accessing and "executing" application level events  (Read 2511 times)
ML
« on: May 08, 2006, 10:12:38 PM »
I am able to access The app level events, however, I can not get the events to trigger. VBA is initialzing when I start ACAD, so that is not the problem, but I am not sure what to do next.
Chuck Gabriel
Re: Accessing and "executing" application level events
« Reply #1 on: May 09, 2006, 08:15:02 AM »
Application-level events aren't quite as convenient as document-level events.
Perhaps some sample code will help.
In a standard module:
Option Explicit
Public appEvents As clsAppEvents
Sub Initialize()
  ThisDrawing.SetVariable "FILEDIA", 1
  If appEvents Is Nothing Then
    Set appEvents = New clsAppEvents
  End If
End Sub
Sub Terminate()
  Set appEvents = Nothing
End Sub
In a class module called clsAppEvents:
Private WithEvents m_objApp As AcadApplication
Private Sub Class_Initialize()
  Set m_objApp = ThisDrawing.Application
End Sub
Private Sub Class_Terminate()
  Set m_objApp = Nothing
End Sub
Private Sub m_objApp_SysVarChanged(ByVal SysvarName As String, ByVal newVal As Variant)
  If SysvarName = "FILEDIA" Then
    If newVal = 0 Then
      If StrComp(ThisDrawing.GetVariable("CMDNAMES"), "SETVAR", vbTextCompare) <> 0 Then
      End If
    End If
  End If
End Sub
You have to manually call the Initialize subroutine located in the standard module for this to work.
