Author Topic: Wildcard loading of linetypes ...  (Read 2333 times)
« on: May 08, 2006, 01:26:13 PM »
A friend of mine just asked me how to do it, this is one simplistic answer --
(defun LoadLineTypes ( lineTypeSpec lineTypeFileName / result )
    (if (findfile lineTypeFileName)
        (vl-catch-all-apply
           '(lambda ( )
                (vla-load
                    (vla-get-linetypes
                        (vla-get-activedocument
                            (vlax-get-acad-object)
                    lineTypeSpec
                    lineTypeFileName
                (setq result t)
    result
If the the linetype already exists in the drawing or the specified linetype doesn't exist in the linetype definition file or said file doesn't exist / is corrupt the function will return nil. Accordingly, the function will return t on a successful load. As such, the caller may wish to some some preprocessing / prequalification before invoking if they wish for the calling logic to branch appropriately.
While one could be more ambitious and perform all the noted scan / prequalifications I opted to keep it lean and mean per the original inquirey.
Example use --
(LoadLineTypes "continuous" "acad.lin")
Returns nil because "continuous" is already defined in drawing.
Assuming linetype "hidden" doesn't exist in drawing and is defined in acad.lin --
(LoadLineTypes "hidden" "acad.lin")
Returns t.
A second call --
Returns nil because the "hidden" linetype is already defined.
If all linetypes are purged from drawing, then this call (which uses the wild carding) --
(LoadLineTypes "*" "acad.lin")
Returns t the first time it's invoked, nil thereafter (all things remaining constant) for the reasons noted above.
Cheers.
Re: Wildcard loading of linetypes ...
« Reply #1 on: May 09, 2006, 05:53:10 PM »
Well I liked it. 8-)
« Reply #2 on: May 09, 2006, 06:25:18 PM »
Always the gentleman and scholar, thank you Alan!
