Author Topic: Help but please no code.  (Read 18466 times)
daron
« Reply #30 on: March 04, 2004, 07:57:45 AM »
What CAB's done with the value of wid and len is what I meant by separating out the values.
« Reply #31 on: March 04, 2004, 09:52:17 AM »
Here is a visual example.
DEVITG
Going far beyond
« Reply #32 on: March 05, 2004, 06:35:36 PM »
Could be "MINSERT"  a good way to draw the blocks on?
As defined length fractions distance as
ABBBBBA
The width could be
CDDDDDC
So the insert point should be the A and C distance  from origin
The row number =  by the previous user imput
The column number = by the same way
The row space A
The column space D
Even the angle could match the angle of the room .
« Reply #33 on: March 05, 2004, 08:30:21 PM »
I don't know if minsert would be a good option since it inserts in a complete grid...
hudster
« Reply #34 on: March 31, 2004, 06:46:11 AM »
I've been working on this in my very limited free time and I've come up with this
;;;Lighting array lisp routine
;;;Created by Andy Hudson
;;;March 2004
(defun c:ltg (/ X1 Y1 FX FY P1 PX PY block PXA PYA) ;set as local variables
  (setq X1 (getdist "\nInput length of room along X Axis: ")) ;get length
 (setq Y1 (getdist "\nInput width of room along Y Axis: ")) ;Get width
  (setq FX (getint "\nInput No of fittings along X Axis: "))
  (setq FY (getint "\nInput No of Fittings along Y Axis: "))
  (setq P1 (getpoint "\nSelect the lower left hand corner: ")) (terpri) ;set the 0,0 point
  (command "UCS" "O" P1)
  (setq P1 (LIST 0 0))
  (setq PX (/ X1 FX)) ;;length divide by fittings
  (setq PXA (/ (/ X1 FX) 2.0)) ;;divided by 2
   (setq PY (/ Y1 FY)) ;;width divided by fittings
  (setq PYA (/ (/ Y1 FY) 2.0)) ;;divided by 2
  (setq block (getstring "Enter block name you wish to insert: ")) ;;get block
  (command "-insert" block (list PYA PXA) "1" "" "0") ;;insert block
  (COMMAND "-ARRAY" "LAST" "" "RECTANGULAR" FY FX PY PX)
  (COMMAND "UCS" "P")
  (COMMAND "UCS" "P")
 (princ) ;;clean exit
it's almost there but it doesn't quite work right and I can't figure out why.
this is an image of how I want it to lay out the fittings but it's always off a wee bit.
Any Ideas?
SMadsen
« Reply #35 on: March 31, 2004, 08:43:39 AM »
Andy, I haven't tried your routine but could running osnaps cause the UCS to snap to another point than P1? Just a thought.
hudster
« Reply #36 on: March 31, 2004, 09:09:11 AM »
I've tried it with snaps off, but it's still out.
not by much only 50mm, but enough to annoy me. :cry:
hudster
« Reply #37 on: March 31, 2004, 09:29:48 AM »
it was the snaps, I changed the osmode to 103 and it worked.
But it threw up another problem.  the routing only works in square grids, i.e 2X2 , 3X3, 4X4 etc.
if you try 2X4 it doesn't work.
Someone in my work suggested it may be to do with integers and real numbers.  but I don't know, I'm new to lisp and every function is a discovery to me.
SMadsen
« Reply #38 on: March 31, 2004, 10:30:48 AM »
Nope, GETDIST returns reals so that part is fine. Just noticed that you've switched x and y in the INSERT command though:
should be
(command "-insert" block (list PXA PYA) "1" "" "0")
SMadsen
« Reply #39 on: March 31, 2004, 10:48:08 AM »
Try this minor alteration. Instead of messing with UCS, it merely offsets the point with the lower left point in P1.
Also, undo is added and osnaps are turned off temporarily.
(defun c:ltg (/ X1 Y1 FX FY P1 PX PY block PXA PYA osm)
  (setq PX (/ X1 FX))
  (setq PXA (+ (car P1) (/ PX 2.0)))
  ;;divided by 2
  ;; - plus X coord of P1
  (setq PY (/ Y1 FY))
  (setq PYA (+ (cadr P1) (/ PY 2.0)))
  ;;divided by 2
  ;; - plus Y coord of P1
  (setq block (getstring "Enter block name you wish to insert: ")) ;get block
  ;; - If block exists then go ahead
  (cond ((tblsearch "BLOCK" block)
         ;; - Done with user input -> set OSMODE to zero
         (setq osm (getvar "OSMODE"))
         (setvar "OSMODE" 0)
         ;; - Let user be able to undo
         (command "UNDO" "Begin")
         ;;insert block
         (command "UNDO" "End")
         (setvar "OSMODE" osm)
  ;;clean exit
hudster
« Reply #40 on: March 31, 2004, 01:53:13 PM »
That works a lot better than my version.
CAR and CADR are both new functions to me,  like I said, it's all new to me.
Now for stage two, working out how to insert arrays into rooms at a slant.
I'm looking at both the getangle and getorient functions to do this, am I on the right track?
SMadsen
« Reply #41 on: March 31, 2004, 02:44:36 PM »
Yes, that would be the right track if it should ask for an angle. But it could still be asking for a distance (either with GETDIST as it is now, or with GETPOINT's) and then use ANGLE to calculate the angle.
hudster
« Reply #42 on: April 11, 2004, 02:56:46 PM »
there is a problem with this lisp, it does work, until you try to put a row of fittings when there is only 1 row on the Y axis.  then it seems to fall down.
no matter how hard I look i can't see where it goes wrong.
Any ideas?
« Reply #43 on: April 11, 2004, 04:51:15 PM »
This was without the angle.
Code removed
« Reply #44 on: April 11, 2004, 06:30:41 PM »
Here is some help with the angle. :)
(defun c:ltg (/ x1 y1 fx fy p1 px py block pxa pya osm newbies elast e ang eblk)
  (setq x1 (getdist "\nInput width of room along X Axis: "))
  (setq y1 (getdist "\nInput length of room along Y Axis: "))
  (setq fx (getint "\nInput No of fittings along X Axis: "))
  (setq fy (getint "\nInput No of Fittings along Y Axis: "))
  (setq p1 (getpoint "\nSelect the lower left hand corner: "))
  (setq ang (getangle p1 "\nSelect angle of room width (x-axis): <0>"))
  (if (null ang)
    (setq ang 0)
    (setq ang (* 180.0 (/ ang pi))) ; Radians to Degrees
  (if (or (null fx) (< fx 2))
    (setq fx  1
          px  (/ x1 2)
          pxa (+ (car p1) px)
    (setq px  (/ x1 fx) ;width divided by fittings
          pxa (+ (car p1) (/ px 2.0)) ;divided by 2 plus X coord of P1
  (if (or (null fy) (< fy 2))
    (setq fy  1
          py  (/ y1 2)
          pya (+ (cadr p1) py)
    (setq py  (/ y1 fy) ;length divide by fittings
          pya (+ (cadr p1) (/ py 2.0)) ;divided by 2 plus Y coord of P1
  ;; get block name , default name if enter only
  (setq block
         (getstring "\nEnter block name you wish to insert: <RC-Light> ")
  (if (or (= block "") (null block)) ; use default name
    (setq block "RC-Light")
         (setvar "OSMODE" 0)
         (setq elast (@cv_entlast))
         (setq newbies (ssadd)) ;empty selection set
         (command "-insert" block (list pxa pya) "1" "" 0)
         (setq eblk (@cv_entlast))
         (ssadd  eblk newbies)
         (command "ARRAY" eblk "" "RECTANGULAR" fy fx)
         (if (> fy 1)
           (command py)
         (if (> fx 1)
           (command px)
         (if (/= ang 0)
             (setq e (if elast
                       (entnext elast)
                       (entnext)
             (while e
               (ssadd e newbies)
               (setq e (entnext e))
             (command ".rotate" newbies "" p1 ang)
        ;;  ELSE =====================================
        ((prompt (strcat "\n" block " Block not found."))
  (princ) ; clean exit
;; Function to get the absolutely last entity in the database:
(defun @cv_entlast (/ e elast)
  (setq elast (entlast))
  (while (setq e (entnext elast))
    (setq elast e)
  elast
