Author Topic: Divide number in text by 25.4 (to metric)?  (Read 1962 times)
Biscuits
« on: March 29, 2006, 01:40:07 PM »
I have a large drawing, which contains dims that were exploded in the past by some highly intelligent life form. (management ?).
I have to convert this drawing from metric to inches with 3 decimal places. I’m looking for a routine that would let me:
1.   Select the text in these exploded dims
2.   Divide the current value by 25.4
3.   Replace the old value with the new
This does not have to be a global thing. I prefer single selection.
Any help would be greatly appreciated. Using ACAD2002 with Windows XP Professional
Many thanks
« Last Edit: March 29, 2006, 03:18:22 PM by CAB »
Jürg Menzi
  • Oberegg, Switzerland
Re: Divide number by 25.4
« Reply #1 on: March 29, 2006, 02:03:47 PM »
Does this work for you?
(defun C:Dec2Inch ( / CurSet NewStr OldStr TxtObj)
 (if (setq CurSet (ssget "_:S:E:L" '((0 . "MTEXT"))))
   (setq TxtObj (vlax-ename->vla-object (ssname CurSet 0))
         OldStr (vla-get-TextString TxtObj)
         NewStr (rtos (/ (atof OldStr) 25.4) 2 3)
   (vla-put-TextString TxtObj NewStr)
A computer's human touch is its unscrupulousness!
MENZI ENGINEERING GmbH
Current A2k16... A2k24 - Start R2.18
Andrea
« Reply #2 on: March 29, 2006, 02:25:48 PM »
dimension same layer as text ?
same color as text ?
same size as text ?
you can use filter...
Keep smile...
Biscuits
« Reply #3 on: March 29, 2006, 02:41:23 PM »
Jurg had the perfect routine.
Thank you very much (Swiss quality strikes again)
