Author Topic: Automatic Bevel Creator  (Read 3750 times)
Dr. After
« on: January 25, 2006, 10:02:00 AM »
Anyone know of just a simple little diddy that could make a simple little bevel when selecting a line through an mview?
David Hall
  • Automatic Duh Generator
Re: Automatic Bevel Creator
« Reply #1 on: January 25, 2006, 10:21:15 AM »
need a little more info on what your trying to do
Dr. After
« Reply #2 on: January 25, 2006, 11:23:07 AM »
hmmm....
Let's say I have a layout with an mview on it.  In that mview I have a line that is not vertical or horizontal.  I would like to be able to click a button or type a command that would prompt me to select two points or a line.  Then when I select those points or line, I would like it to create something like this:
                12
      ________________
  3 |
I would like to be able to have a consistent end result that I could tweak to look like my dimensioning and such.  But right now I have nothing, so anything would be better.  And after doing a bit of searching, I came up empty and was wondering what was out there.
David Hall
« Reply #3 on: January 25, 2006, 11:32:00 AM »
OK, now we have something.  First question, is it always angled such that the rise is less than the run?
Dr. After
« Reply #4 on: January 25, 2006, 11:52:31 AM »
Nope.  And it could be running upwards, downwards, leftwards, rightwards, sidewards, forwards, backwards, aroundwards, ...  just not flatwards.  Really I just need it to read a 2D line running in any direction.  It would be nice to be able to chose which side of the line the bevel would be on and have an option for if an extension line were necessary.
David Hall
« Reply #5 on: January 25, 2006, 02:03:19 PM »
what about scale? do you need to consider dimscale for the text height and offset for extension lines
TimSpangler
  • CAD Naked!!
« Reply #6 on: January 25, 2006, 02:13:11 PM »
DDSlope
Try this one
ACA 2015 - Windows 7 Pro
Dr. After
« Reply #7 on: January 26, 2006, 09:20:01 AM »
This will all be in paper space, so a common size would be fine.  1/8" letters and large enough to make it ledgeable.
Dr. After
« Reply #8 on: January 26, 2006, 09:27:59 AM »
DDSlope
Try this one
Nice!  I like the user interface.  I will need it to have stacked dimension though...  Also it doesn't draw both lines for the right triangle, but instead draws two lines on the 12 side.
So this one doesn't work, but is darn close to working right.
