Author Topic: Tiny topic  (Read 2189 times)
Tiny topic
« on: November 23, 2005, 10:54:17 AM »
Do you ever have need to normalize values that are approaching, but not quite zero, like -1.83691e-016, that is, have it evaluated as zero if it's smaller than an arbitrary threshold?
I had a colleague who needed something like this so I thought I'd share it.
(defun Normalize ( x )
        ((zerop x) x)
        ((eq 'int (type x)) x)
        ((equal 0 x 1e-15) 0.0)
        (x)
(Normalize 0)
==> 0
(Normalize 0.0)
==> 0.0
(Normalize 1e-5)
==> 1.0e-005
(Normalize -1.83691e-016)
==> 0.0
(mapcar 'Normalize '(1.0 -1.83691e-016 0.0))
==> (1.0 0.0 0.0)
[/color]
The idea is that it won't change ints to reals and vice versa, but it does return 0.0 for minuscule values.
Obviously the 1e-15 fuzz factor is subjective.
What would you use?
Any other thoughts?
Re: Tiny topic
« Reply #1 on: November 23, 2005, 11:16:22 AM »
Interesting, I have always used just the fuzz.
Would you ever have need of this?
((equal 0 (- x (fix x)) 1e-15) (float (fix x)))
Re: Tiny topic
« Reply #2 on: November 23, 2005, 11:43:27 AM »
Hmmm. let me play with that Allan. Thank you.
Tangent: My normalize function was lifted from this little thing I penned long ago:
(defun IsZero ( x )
    (or (zerop x)
        (equal x 0 1e-15)
Re: Tiny topic
« Reply #3 on: November 23, 2005, 12:00:05 PM »
Interesting func Allan: Round a number to its integer value if it's fractional portion is below the threshold.
