Author Topic: Batch file help  (Read 3284 times)
Batch file help
« on: September 08, 2005, 04:18:52 PM »
So we have a login script.
First disconnect drive then reconnect.
How would I check to see if the drive is connected......and then disconnect. If it does not exist....ignore it?
Something like this:
If Net Use F: = true
Net Use F: /Del /YES
else goto
If Net Use J: = true
Net Use J: /Del /YES
thanks,
Ron
deegeecees
Re: Batch file help
« Reply #1 on: September 08, 2005, 04:26:13 PM »
Here is what I was handed by Hudster:
@echo off
net use p: /delete
net use p: \\lisledc1\projects
net use q: /delete
net use q: \\lisledc2\projectscomed
net use s: /delete
net use s: \\lisledc2\programs
net time \\lisledc2 /set /yes
If "%OS%" == "Windows_2000" goto skip
:skip
It doesn't take into consideration current connection status. Its more of a brute force method. Delete drive, then reconnect using the proper mapping.
« Last Edit: September 08, 2005, 04:33:05 PM by deegeecees »
Bob Wahr
Re: Batch file help
« Reply #2 on: September 08, 2005, 04:56:33 PM »
you can either pick a file that will always be on the drive or make a bogus file like "connected.txt", then do
If not exist F:\connected.txt
goto skipF
:skipf
If not exist J:\connected.txt
goto skipJ
:skipJ
*anything else you want to do before leaving*
echo Da shizzle is finizzled.
Re: Batch file help
« Reply #3 on: September 08, 2005, 05:08:45 PM »
Thanks Bob, I'll give it a try.
Bob Wahr
Re: Batch file help
« Reply #4 on: September 08, 2005, 05:15:58 PM »
It might need some tweaking, been awhile since I've been up to BAT, but it should get you started.
Re: Batch file help
« Reply #5 on: September 26, 2005, 01:12:37 PM »
Hey Bob (or anyone else),
Do you know how to compare the date modified attribute or filesize for two files.
Something like:  if c:\file1size equal c:\file2size goto skip
You're solution worked for my other question....you don't have to have a file to look for though....it works just checking for a folder location.
if not exist "%programfiles%\AutoCAD Tools\" goto SKIPAROONIE
"S:\-AutoCAD Routines-\Updater\Update Lisp Routines.bat"
:SKIPAROONIE
Bob Wahr
Re: Batch file help
« Reply #6 on: September 26, 2005, 01:45:42 PM »
maybe with COMP
Re: Batch file help
« Reply #7 on: September 26, 2005, 03:04:31 PM »
FYI..
It was easier to use a 3rd party app (from what I read)...
http://www.programmersheaven.com/zone16/cat913/19947.htm
Syntax: gscmp [FILE1] [FILE2]
Return Values
0 - The files are identical.
1 - The files differ in size.
2 - The files differ in content.
The batch file looks like this:
gscmp "C:\file1" "X:\file2"
if %errorlevel% == 0 goto SKIPINSTALL
F:\somepath\myprog.exe
:SKIPINSTALL
Andrea
Re: Batch file help
« Reply #8 on: September 26, 2005, 07:17:20 PM »
;;to detect if drive exist.
(vl-file-size "k:/") ;;return nil if not
;;or
(vl-file-directory-p "v:/")
;;to detect the size of the file (if exist)
(vl-file-size "c:/test.txt");;return nil if not exist
;;to detect the file Date
(vl-file-systime "c:/program files/AutoCAD 2004/sample/visuallisp/yinyang.lsp")
so I think with theses command you can do everything you need...
But if you need this to do a Batch file scripting...
take a look Here...
« Last Edit: September 26, 2005, 07:29:51 PM by Andrea »
Keep smile...
Re: Batch file help
« Reply #9 on: September 26, 2005, 07:24:54 PM »
Yep, Lisp will work Andrea . but he is after a system Script < .BAT file >
Andrea
Re: Batch file help
« Reply #10 on: September 26, 2005, 07:31:14 PM »
Oops..... :|
Keep smile...
