Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Periodic flag in a spline doesn't match periodic value shown in properties?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Periodic flag in a spline doesn't match periodic value shown in properties? (Read 846 times)
V@no
Newt
AutoCAD 2023
on:
April 27, 2024, 09:59:59 AM »
I've been playing around with
group 70
of a spline and noticed that "periodic" bit (bit 2) could be set, but spline's properties panel shows it as not set:
Code - Auto/Visual Lisp:
[Select]
logand
cdr
assoc
70
entget
SSNAME
ssget
":S"
0
"SPLINE"
0
2
Why is that?
Thanks.
Logged
It's Alive!
Retired
Needs a day job
AKA Daniel
WWW
Re: Periodic flag in a spline doesn't match periodic value shown in properties?
Reply #1 on:
April 27, 2024, 10:36:43 PM »
PyRx shows False
Code - Python:
[Select]
import
traceback
from
pyrx_imp
import
Rx
Ge
Gi
Db
Ap
Ed
Gs
def
PyRxCmd_doit
None
try
db
Db.
curDb
es
Ed.
Editor
entSel
\n
Pick it: "
Db.
Spline
desc
if
es
0
Ed.
PromptStatus
eOk
raise
Exception
"Oops {}: "
format
es
0
sp
Db.
Spline
es
1
print
"isPeriodic= "
sp.
isPeriodic
except
Exception
as
err:
traceback
print_exception
err
Command: DOIT
Pick it: isPeriodic= False
Logged
https://github.com/CEXT-Dan/PyRx
https://pyarx.blogspot.com/
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
