Author Topic: [XDrX-PlugIn(154)] Get the total length of overlapping segments  (Read 209 times)
xdcad
1. xdrx-pointmonitor
    Through the point monitor callback function _callback, draw dynamic memory MTEXT, POLYLINE screen vector, and dynamic drag
2. xd::geom:getoverlaps
    Get Entitiy List of overlapping segments
Functions: Obtain the memory geometric entities of the overlapping segments of two polylines (determine whether the two polylines will overlap in the future)
parameter:
    1. e1,e2 ---- polyline entity name, or geometric entity name, or point table
    2. mode --- t: returns the geometric entity table, nil: returns t or nil
(defun xd::geom:getoverlaps (e1 e2 mode / g1 g2 gint curveint ret _getparam ranges ranges1)
  (defun _getparam (e1 / g1)
      ((= (type e1) 'list)
       (setq g1 (xdge::constructor "kCompositeCrv3d" e1))
      ((and (= (type e1) 'ename)
    (xdrx-object-iskindof e1 "AcDbCurve")
       (setq g1 (xdge::constructor e1))
      ((xdge::type e1)
       t
      (t
       (setq g1 nil)
    g1
  (setq g1 (_getparam e1)
g2 (_getparam e2)
  (if (and g1 g2)
      (setq curveint (xdge::constructor "kCurveCurveInt3d"))
      (setq gint (xdge::setpropertyvalue curveint "set" g1 g2))
      (setq ret (> (xdge::getpropertyvalue gint "numOverlaps") 0))
      (if (and mode ret)
  (setq ranges (xdge::getpropertyvalue gint "overlapranges" t)
ranges1 (mapcar 'car ranges)
  (setq ret
(mapcar '(lambda (x)
    (setq tmp (xdge::copy g1))
    (xdge::setpropertyvalue tmp "setinterval" x)
ranges1
  (xdge::free g1 g2 curveint gint ranges)
  ret
(defun c:tt ()
  (defun *error* (msg)
    (xdrx-entity-delete ents)
    (xdrx-pointmonitor)
    (xdrx-end)
    (redraw)
  (defun _callback (dynpt)
    (redraw)
    (xd::pnts:mark verts 2 0.025)
    (xdrx-setpropertyvalue
      ents
      "constantwidth"
      (* (getvar "viewsize") 0.015)
      "color" 6
    (xdrx-grdraw 6 ents)
    (xd::grdraw:drawtext
  txt
  totallen
  (polar dynpt (/ pi 4.0) (/ (xd::doc:getpickboxheight) 2.0))
  1
  (* (getvar "viewsize") 0.03)
  6
  (getvar "ucsxdir")
  nil
  8
  (xdrx-begin)
  (if (and (setq e1 (car (xdrx-entsel
   (xdrx-string-multilanguage
     "\n拾取第一条多段线<退出>:"
     "\nPick the first polyline<Exit>:"
   '((0 . "*polyline"))
   (setq e2 (car (xdrx-entsel
     "\n拾取第一条多段线<退出>:"
      (if (setq data (xd::geom:getoverlaps e1 e2 t))
  (setq txt (xdrx-mtext-make)
nums (length data)
tlen (apply '+ (xdrx-getpropertyvalue data "length"))
totallen (xdrx-string-formatex
     "重叠段 %d,总长度 %.1f\r\n"
     "Overlapping segment %d.\r\nTotal length=%.1f"
   nums
   tlen
verts (xdrx-getpropertyvalue data "vertices")
ents (xdrx-entity-make data)
verts (xd::list:flat-point verts)
  (xdrx-pointmonitor "_callback")
  (if (getpoint)
      (xdrx-entity-make txt)
  ;(xdrx-entity-delete ents)
  (xdrx-pointmonitor)
  (redraw)
  (xdrx-end)
The above LISP code uses the XDRX-API, which can be downloaded from https://github.com/xdcad/XDrx-API
The XDRX API encapsulates AcDb, AcEd, AcGe, AcBr... C++ library, using C++ methods to develop LISP programs.Thousands of Lisp functions are available.
http://bbs.xdcad.net
