Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Draw Sun Angle in Plan
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Draw Sun Angle in Plan (Read 2148 times)
GDF
Water Moccasin
on:
June 22, 2018, 08:15:43 AM »
I'm fishing for a lisp routine that will draw in plan the sun angle based upon AutoCAD's Geographic Location palette settings.
Logged
GDF
Water Moccasin
Re: Draw Sun Angle in Plan
Reply #1 on:
June 22, 2018, 08:34:30 AM »
I have found this tool:
http://andrewmarsh.com/apps/releases/sunpath2d.html
Logged
huiz
Swamp Rat
Certified Prof C3D
Reply #2 on:
June 22, 2018, 10:01:39 AM »
In 3D even prettier:
http://andrewmarsh.com/apps/staging/sunpath3d.html
Logged
GDF
Water Moccasin
Reply #3 on:
June 22, 2018, 01:36:14 PM »
(defun C:SUN1 ()(command "start" "
")(princ))
(defun C:SUN2 ()(command "start" "
http://www.sunpath.in/#/29.1617,-82.1779,12/2018.06.22/13:51
")(princ))
Logged
GDF
Water Moccasin
Reply #4 on:
June 24, 2018, 12:27:26 PM »
Ok, you math-trig masters:
What I am trying to achieve is the approximate shadow angle calculator for a vertical wall...
solar zenith angle
. by plugging in the necessary variables.
(hopefully I'm expressing this correctly)
Lattitude
Time of day
Month
To get the
solar zenith angle
Can anyone help me with a calculator formula example?
https://en.wikipedia.org/wiki/Solar_azimuth_angle#Formulas
Logged
huiz
Swamp Rat
Certified Prof C3D
Reply #5 on:
June 24, 2018, 02:47:30 PM »
You can download an Excel file here:
https://www.esrl.noaa.gov/gmd/grad/solcalc/NOAA_Solar_Calculations_day.xls
Fill in the location and date and it will fill everything you need. Formulas are in the cells.
Be aware of the theoretical results, For really accurate calculations you need to respect the influence of the atmosphere, true north and the elevation of EG (or bumpy terrains). I think a few degrees are acceptable for theoretical calculations.
Logged
GDF
Water Moccasin
Reply #6 on:
June 24, 2018, 03:04:30 PM »
I'm also looking for additional drawing files from different latitudes like the one enclosed for London:
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
