All,
I have a drawing that contains many individual pieces of MText that look like they should belong to "paragraphs", but each line is a separate piece of MText. I need to combine them each pseudo-paragraph into a true piece of MText.
I realize that this can be done with manually TXT2MTXT, but this needs done to a number of drawings, so I'd rather not need user interaction. I'd like it to do the following:
- evaluate each piece of text to determine if it's part of a paragraph (i.e. whether there is text above or below it, based on known line spacing)
- determine which piece is the 1st line of the paragraph (i.e. using the known spacing, there's no more text above it)
- combine it with the text below it (the rest of the paragraph, again using the known spacing)
BTW, the line spacing is <txt ht> * 1.61111.
It seems like a recursive exercise, but I don't do recursive very well.
Any takers?
Thanks,
Chris
