Drawing a blank! We draw property maps for mineral tenure by doing all drafting in autocadmap (its so easy), attach object data to the polygons, export to arcview and then link to a database and put the result on an ArcIMS server. Problem is too many people are updating and sometimes object data isn't always attached. This is just a utility to find those polygons. I can make the selection set for them -ss but I can't for the life of me figure out how to highlight them.
![embarassed :oops:](http://www.theswamp.org/Smileys/black/embarrassed.gif)
Can someone give me a hint?
;;; Utility to find polygons that are missing object data.
;;; The wrapped function to get the object data names is from Rakesh Rao
(defun c:no_od (/ item table_attached ss sset p1 p2)
(setq ss (ssadd)) ; make an empty selection set to put naked polygons
(prompt "\nSelect Objects to test by Window")
(setq p1 (getpoint "\nFirst Corner: "))
(setq p2 (getcorner p1 "\nSecond Corner: "))
(setq sset ; this is the selection set of polygons to test
(ssget
"c"
p1
p2
(list (cons 0 "LWPOLYLINE"))
(if (= sset nil) ; if nothing selected
(progn ; do this
(alert "No polylines selected!")
(exit)
) ;end of routine to run if no polygons selected
(progn ; if polygons have been selected do this
(setq ctr 0) ;set the counter to zero
(while (and sset (> (sslength sset) 0))
(setq item (ssname sset 0)) ;extract the name of first entity in the list.
(setq table_attached (AM_GetTables item))
(if (= table_attached nil) ; if no object data
(ssadd item ss) ; add the item to the set to highlite
(ssdel item sset) ; delete the item from selection set being tested
(ssdel item sset) ; otherwise delete the item from selection set being tested
(setq ctr (+ ctr 1)) ; increase the counter
) ; get next item
) ; end of routine to run if polygons selected
) ; end of if
(setq sset nil) ; get rid of this now empty selection set
;;;(???????) ; highlite the ss selection set
(princ) ; clean exit
(defun AM_GetTables (ename / Tables)
(setq Tables (ade_odgettables ename)) ; get the table names
(if Tables ; if there are tables
(if (not (listp Tables)) ;and if not only one table make them a list
(setq Tables (list Tables))
(setq Tables (mapcar 'strcase Tables)) ; convert to upper case
Tables ; return the tables
