Author Topic: XREF insanity  (Read 2803 times)
DIW_CADtech
  • Push limits, embrace success, & discard failure.
XREF insanity
« on: September 01, 2015, 11:30:06 AM »
I wasn't part of a project that was put together and submitted earlier this year.  Our client doesn't want any XREFS and I have several Mechanical drawings with 3d objects.  At first someone used the E-transmit to bind all the xrefs and send it to the client.  6 months later, the client is finally getting around to posting files to there database, only to realize a great deal of XREFS are not included in the package.
It has now become my problem.
I have several mechanical and structural drawings that have multiple layers deep of nested XREF's.   I re-etransmitted this file to a new directory, and copied over any files that were missed in the E-transmit.  But when I go to the botom of the Nested XREFS and try to start binding, linework starts evaporating.  One in particular is a 3D model of a tank.
Looking for any advise/helpful links/suggestions  to get all of these files bound and visibly matching there unbound cousins.
« Last Edit: September 01, 2015, 11:33:40 AM by DIW_CADtech »
I am very  trainable....   (forgive my spelling)
Rob...
Re: XREF insanity
« Reply #1 on: September 01, 2015, 11:33:34 AM »
A work around would be to insert the XREF files as blocks (as that is the end result of binding) and see if the linework still disappears.
CAD Tech
DIW_CADtech
Re: XREF insanity
« Reply #2 on: September 01, 2015, 11:35:52 AM »
I will try that, but that's a lot of work..
still looking for better answers...
Rob...
Re: XREF insanity
« Reply #3 on: September 01, 2015, 11:39:58 AM »
A better answer is to do a thorough investigation to find out exactly what is giving you the errors and adjust accordingly but that's a lot of work, too.
CAD Tech
cadtag
Re: XREF insanity
« Reply #4 on: September 01, 2015, 01:05:41 PM »
Contract ought to have a cut-off date for submittal review.  After 30 days, it's automagically approved.
DIW_CADtech
Re: XREF insanity
« Reply #5 on: September 01, 2015, 01:19:52 PM »
It would be nice if we could throw that flag but this is one of our largest clients.
Now I am dealing with AutoCAD Proxy_Entity's...   I tried to WBlock a drawing so I could insert it and it did not take the proxy entities with it.
Rob...
Re: XREF insanity
« Reply #6 on: September 01, 2015, 01:52:42 PM »
Do you have the necessary object enablers?
That may be why they weren't binding properly.
BTW, you do not have to WBlock. You can insert the XREF file as a block. (That is unless you are modifying it for insertion.)
CAD Tech
DIW_CADtech
Re: XREF insanity
« Reply #7 on: September 01, 2015, 02:11:31 PM »
How do I aquire/install object enablers?
Rob...
CAD Tech
DIW_CADtech
Re: XREF insanity
« Reply #9 on: September 01, 2015, 03:28:32 PM »
It seems several items were generated with a 3D software.  I'm handing off all the XREF's to be "Flattened" to 2D via verious programs.  This should solve the problem.
.. once that is fixed, I still have a lot of nested XREFs
Is there a way to capture the 3rd and 4th level of xrefs when you E-Transmit?
Re: XREF insanity
« Reply #10 on: September 01, 2015, 03:30:29 PM »
Why dont you eTransmit through the set "backwards" -i.e. start with the "backgrounds" and work upwards?
DIW_CADtech
Re: XREF insanity
« Reply #11 on: September 01, 2015, 03:34:49 PM »
Once the 3D files are converted to 2D.. I will follow that method.. bind at the lowest level then step up through the hierarchy of XREFs
Rob...
Re: XREF insanity
« Reply #12 on: September 01, 2015, 08:06:11 PM »
<---Liking this approach.
CAD Tech
