Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
Palette not Docking Civil 3d 2016
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Palette not Docking Civil 3d 2016 (Read 2242 times)
nobody
Swamp Rat
.net stuff
on:
August 17, 2015, 12:35:30 AM »
Anyone elses .net palettes not docking like they should in 2016? Works fine in 2014.
Logged
King Gator
C3D user & customizer
Re: Palette not Docking Civil 3d 2016
Reply #1 on:
August 17, 2015, 12:13:03 PM »
No problems with any of mine. Can you give an example of the issue(s) you are seeing?
Logged
nobody
Swamp Rat
.net stuff
Reply #2 on:
August 17, 2015, 09:56:47 PM »
Docks normally in 14. In 16 it doesn't dock and cuts off the bottom portion of the palette. Corrects itself when I manually dock it though.
Logged
BlackBox
King Gator
Reply #3 on:
August 18, 2015, 01:15:32 AM »
Not sure if this will help, but if you're hosting a WPF Control in your PaletteSet, you can bind/link the bottom button positions to the bottom of the Control's frame, rather than what seems to be a static measurement from the + and - TextBoxes.
Logged
nobody
Swamp Rat
.net stuff
Reply #4 on:
August 18, 2015, 01:31:37 AM »
Thanks blackbox... I'll give that a shot.
Logged
BlackBox
King Gator
Reply #5 on:
August 18, 2015, 01:51:43 PM »
Quote from: Alien on August 18, 2015, 01:31:37 AM
I found this useful way back when:
http://through-the-interface.typepad.com/through_the_interface/2009/08/hosting-wpf-content-inside-an-autocad-palette.html
Cheers
Logged
nobody
Swamp Rat
.net stuff
Reply #6 on:
August 19, 2015, 10:43:44 PM »
Turns out it didn't like me leaving the min size at 0,0... I had been setting the min size through the main palette creator code. When I set the minimum in the image below it appeared to fix my problem.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
