Author Topic: Count Blocks with Circles and Exploded Circles  (Read 4809 times)
MSTG007
Re: Count Blocks with Circles and Exploded Circles
« Reply #15 on: August 25, 2015, 01:13:36 PM »
geesh. Dude... you got it. wow. Thanks for everyones help on it! I greatly appreciated it.
Civil3D 2020
« Reply #16 on: August 25, 2015, 01:14:57 PM »
If there are 525 circles, than it should count them as 525... I guess you missed one hidden to you somewhere in your DWG...
Note that you are counting circles within block definitions only once, and not for each reference of the definition; aside, I shudder to think how many times the vl-catch-all-apply expression will error...  :|
MSTG007
« Reply #17 on: August 25, 2015, 01:16:35 PM »
interesting... thinking outside my box again. will this work with counting circles in dynamic blocks as well?
Civil3D 2020
roy_043
  • BricsCAD 18
« Reply #18 on: August 25, 2015, 01:18:02 PM »
Well, I am out.
ribarm
  • Marko Ribar, architect
« Reply #19 on: August 26, 2015, 04:03:52 AM »
FWIW, this will count any entity type within/unbound to any INSERT references nested into any level deep and you may also choose space where those etypes reside...
  1. ;;; (countetype "*" t t) ;; "*" - stretype ; t - unbound ; t - activespace
  2. ;;; (countetype "CIRCLE" t t) ;; "CIRCLE" - stretype ; t - unbound ; t - activespace
  3. ;;; (countetype "LINE" nil t) ;; "LINE" - stretype ; nil - bound to blocks/xrefs nested to any depth ; t - activespace
  4. ;;; (countetype "INSERT" nil nil)  ;; "INSERT" - stretype ; nil - bound to blocks/xrefs nested to any depth ; nil - database
  5.
  6. (defun countetype ( stretype unbound-bound activespace-database / ss n i insref blkbeginslst blkbegin ent l )
  7.   (if (and stretype (not (eq stretype "")) (eq (type stretype) 'STR))
  8.     (cond
  9.       ( (and unbound-bound activespace-database)
  10.         (setq ss (ssget "_X" (list (cons 0 stretype) (cons 410 (if (= (getvar 'cvport) 1) (getvar 'ctab) "Model")))))
  11.         (prompt (strcat "\nTotal : " (if ss (itoa (sslength ss)) "0") " \"" stretype "\"" " unbound to blocks/xrefs in active space\n"))
  12.         (if ss (sslength ss) 0)
  13.       )
  14.       ( (and (not unbound-bound) activespace-database)
  15.         (setq n 0)
  16.         (setq ss (ssget "_X" (list (cons 0 "INSERT") (cons 410 (if (= (getvar 'cvport) 1) (getvar 'ctab) "Model")))))
  17.         (if ss
  18.           (progn
  19.             (repeat (setq i (sslength ss))
  20.               (setq insref (ssname ss (setq i (1- i))))
  21.               (setq blkbeginslst (cons (refnestedblkbeginslst insref) blkbeginslst))
  22.               (setq l nil)
  23.             )
  24.             (foreach blkbegins blkbeginslst
  25.               (foreach blkbegin blkbegins
  26.                 (setq ent blkbegin)
  27.                 (while (setq ent (entnext ent))
  28.                   (if (wcmatch (cdr (assoc 0 (entget ent))) stretype)
  29.                     (setq n (1+ n))
  30.                   )
  31.                 )
  32.               )
  33.             )
  34.           )
  35.         )
  36.         (prompt (strcat "\nTotal : " (itoa n) " \"" stretype "\"" " bound to blocks/xrefs in active space\n"))
  37.         n
  38.       )
  39.       ( (and unbound-bound (not activespace-database))
  40.         (setq ss (ssget "_X" (list (cons 0 stretype))))
  41.         (prompt (strcat "\nTotal : " (if ss (itoa (sslength ss)) "0") " \"" stretype "\"" " unbound to blocks/xrefs in database\n"))
  42.         (if ss (sslength ss) 0)
  43.       )
  44.       ( (and (not unbound-bound) (not activespace-database))
  45.         (setq n 0)
  46.         (setq ss (ssget "_X" (list (cons 0 "INSERT"))))
  47.         (if ss
  48.           (progn
  49.             (repeat (setq i (sslength ss))
  50.               (setq insref (ssname ss (setq i (1- i))))
  51.               (setq blkbeginslst (cons (refnestedblkbeginslst insref) blkbeginslst))
  52.               (setq l nil)
  53.             )
  54.             (foreach blkbegins blkbeginslst
  55.               (foreach blkbegin blkbegins
  56.                 (setq ent blkbegin)
  57.                 (while (setq ent (entnext ent))
  58.                   (if (wcmatch (cdr (assoc 0 (entget ent))) stretype)
  59.                     (setq n (1+ n))
  60.                   )
  61.                 )
  62.               )
  63.             )
  64.           )
  65.         )
  66.         (prompt (strcat "\nTotal : " (itoa n) " \"" stretype "\"" " bound to blocks/xrefs in database\n"))
  67.         n
  68.       )
  69.     )
  70.     (prompt "\nInvalid entity type string specified as starting argument...")
  71.   )
  72. )
  73.
  74. (defun refnestedblkbeginslst ( ref / e )
  75.   (setq ref (tblobjname "BLOCK" (cdr (assoc 2 (entget ref)))))
  76.   (setq e ref)
  77.   (setq l (append l (list ref)))
  78.   (while (setq e (entnext e))
  79.     (if (eq (cdr (assoc 0 (entget e))) "INSERT")
  80.       (progn
  81.         (setq l (append l (list e)))
  82.         (refnestedblkbeginslst e)
  83.       )
  84.     )
  85.   )
  86.   l
  87. )
  88.
  89. ;;; (alert (strcat "Total number of circle entities within DWG is : " (itoa (+ (countetype "CIRCLE" t nil) (countetype "CIRCLE" nil nil)))))
  90.
Regards, M.R.
« Last Edit: August 26, 2015, 08:09:30 AM by ribarm »
M.R. on Youtube
MSTG007
« Reply #20 on: August 26, 2015, 06:00:36 AM »
Woooow. Or whooot!!!!
Civil3D 2020
« Reply #21 on: August 26, 2015, 07:38:47 AM »
I would suggest:
  1. (defun c:cc ( / c d e i l s )
  2.     (while (setq d (tblnext "block" (not d)))
  3.         (setq e (tblobjname "block" (cdr (assoc 2 d)))
  4.               c 0
  5.         )
  6.         (while (setq e (entnext e))
  7.             (if (= "CIRCLE" (cdr (assoc 0 (entget e))))
  8.                 (setq c (1+ c))
  9.             )
  10.         )
  11.         (setq l (cons (cons (cdr (assoc 2 d)) c) l))
  12.     )
  13.     (setq c 0)
  14.     (if (setq s (ssget '((0 . "CIRCLE,INSERT"))))
  15.         (progn
  16.             (repeat (setq i (sslength s))
  17.                 (setq e (entget (ssname s (setq i (1- i)))))
  18.                 (if (= "CIRCLE" (cdr (assoc 0 e)))
  19.                     (setq c (1+ c))
  20.                     (setq c (+ c (cdr (assoc (cdr (assoc 2 e)) l))))
  21.                 )
  22.             )
  23.             (princ (strcat "\n" (itoa c) " circles found."))
  24.         )
  25.     )
  26.     (princ)
  27. )
To account for nested blocks (to any depth):
  1. (defun c:cc ( / cnt def enx idx lst sel )
  2.     (while (setq def (tblnext "block" (not def)))
  3.         (setq lst (circlesinblock (cdr (assoc 2 def)) lst))
  4.     )
  5.     (setq cnt 0)
  6.     (if (setq sel (ssget '((0 . "CIRCLE,INSERT"))))
  7.         (progn
  8.             (repeat (setq idx (sslength sel))
  9.                 (setq enx (entget (ssname sel (setq idx (1- idx)))))
  10.                 (if (= "CIRCLE" (cdr (assoc 0 enx)))
  11.                     (setq cnt (1+ cnt))
  12.                     (setq cnt (+  cnt (cdr (assoc (cdr (assoc 2 enx)) lst))))
  13.                 )
  14.             )
  15.             (princ (strcat "\n" (itoa cnt) " circles found."))
  16.         )
  17.     )
  18.     (princ)
  19. )
  20. (defun circlesinblock ( blk lst / ent enx rtn )
  21.     (cond
  22.         (   (assoc blk lst) lst)
  23.         (   (setq rtn 0
  24.                   ent (tblobjname "block" blk)
  25.             )
  26.             (while (setq ent (entnext ent))
  27.                 (setq enx (entget ent))
  28.                 (cond
  29.                     (   (= "CIRCLE" (cdr (assoc 0 enx)))
  30.                         (setq rtn (1+ rtn))
  31.                     )
  32.                     (   (= "INSERT" (cdr (assoc 0 enx)))
  33.                         (setq lst (circlesinblock (cdr (assoc 2 enx)) lst)
  34.                               rtn (+  (cdr (assoc (cdr (assoc 2 enx)) lst)) rtn)
  35.                         )
  36.                     )
  37.                 )
  38.             )
  39.             (cons (cons blk rtn) lst)
  40.         )
  41.         (   (cons (cons blk 0) lst))
  42.     )
  43. )
