Author Topic: Update existing block with attribute  (Read 1589 times)
FELIX
« on: July 31, 2015, 06:14:11 PM »
A block with two attributes (or more) already has several inserts in the drawing. The same block was updated to have three attributes (or more) put the autoCAD only updates the block drawing and does not update the amount of attributes. There is a simple way of doing this update Autolisp in all blocks of the same name already in the design?
Attached a small example.
OK.
Re: Update existing block with attribute
« Reply #1 on: July 31, 2015, 07:00:41 PM »
Attsync
serge_c
« Reply #2 on: August 03, 2015, 01:37:29 AM »
also , comand  _battman , select your block and "sync " it
FELIX
« Reply #3 on: August 03, 2015, 01:32:14 PM »
ATTSYNC very good.
BATTMAN can not be used in Autolisp but also did not know. Very useful to sort the attributes in a block atributado.
Grateful to everyone.
OK.
