Author Topic: Question about Load lisp with *.mnl  (Read 6269 times)
pedroantonio
Re: Question about Load lisp with *.mnl
« Reply #15 on: April 27, 2014, 04:18:22 PM »
ok ,
  1. (setq filenameL (vl-directory-files "C:\\topocad" "*.lsp"))
  2. (foreach x filenameL
  3.   (load x)
  4.   )
  5.
if i understand now i have to change this "*.lsp" to
  1. (setq filenameL (vl-directory-files "C:\\topocad" "test1.lsp" "test2.lsp" "test3.fas" "test4.vlx" ))
pedroantonio
« Reply #16 on: April 27, 2014, 04:49:20 PM »
i put this lines in a txt file and name it to acaddoc.lsp
  3.   (load x)
  4.   )
When i paste this file in C:\topocad file  my autocad not opening !!! why?
« Reply #17 on: April 27, 2014, 05:31:55 PM »
I would suggest:
(defun load-all-in-folder ( dir )
    (setq dir (vl-string-right-trim "\\" (vl-string-translate "/" "\\" dir)))
    (foreach lsp (vl-directory-files dir "*.lsp" 1)
        (load (strcat dir "\\" lsp) nil)
(load-all-in-folder "C:\\topocad")
This recent thread may also be helpful: Load all LISP files in folders & subfolders.
pedroantonio
« Reply #18 on: April 27, 2014, 06:12:26 PM »
Thank you lee
if i undersant
  1. (load-all-in-folder "C:\\topocad")
  2.  (setq dir (vl-string-right-trim "\\" (vl-string-translate "/" "\\" dir)))
  3.     (foreach lsp (vl-directory-files dir "*.lsp" 1)
  4.         (load (strcat dir "\\" lsp) nil)
  5.     )
  6.     (princ)
  7. )
  8.
 acaddoc.lsp
I try it load all the lisp files , don't load *.vlx files
« Reply #19 on: April 27, 2014, 06:25:01 PM »
No, you first need to define the function (the defun expression) and then call it with the required argument(s) (the load-all-in-folder expression with the given directory).
To include VLX / FAS, add the following to your acaddoc.lsp:
  1. (defun load-all-in-folder ( dir )
  3.     (foreach app
  4.         (apply 'append
  5.             (mapcar
  6.                 (function
  7.                     (lambda ( ext )
  8.                         (vl-directory-files dir ext 1)
  9.                     )
  10.                 )
  11.                '("*.vlx" "*.fas" "*.lsp")
  12.             )
  13.         )
  14.         (eval
  15.             (load
  16.                 (strcat dir "\\" app)
  17.                 (quote (princ (strcat "\nUnable to load " app)))
  18.             )
  19.         )
  20.     )
  21.     (princ)
  22. )
  23. (load-all-in-folder "C:\\topocad")
EDIT: Updated.
EDIT: Actually, this is better:
  3.     (foreach ext '("*.vlx" "*.fas" "*.lsp")
  4.         (foreach app (vl-directory-files dir ext 1)
  5.             (eval (load (strcat dir "\\" app) '(princ (strcat "\nUnable to load " app))))
  6.         )
  7.     )
  8.     (princ)
  9. )
  10. (load-all-in-folder "C:\\topocad")
« Last Edit: April 27, 2014, 06:31:10 PM by Lee Mac »
pedroantonio
« Reply #20 on: April 27, 2014, 06:38:26 PM »
I have an autocad load problem with this code
And with this two codes can not load *.vlx files
« Last Edit: April 27, 2014, 06:42:45 PM by Topographer »
snownut2
  • Bricscad 22 Ultimate
« Reply #21 on: April 27, 2014, 07:10:57 PM »
Lee you are a very patient man.... :laugh:
pedroantonio
« Reply #22 on: April 27, 2014, 07:31:08 PM »
in vlisp editor this code works
  6.         )
  7.     )
  8.     (princ)
  9. )
  11.
How can i load it any time at start up? If i give him a name acaddoc.lsp my autocad didin't load
pedroantonio
« Reply #23 on: April 27, 2014, 07:36:13 PM »
I add t in my *.mnl file and works . I will test more.
RC
« Reply #24 on: April 27, 2014, 08:26:12 PM »
As an option investigate AUTOLOAD
snownut2
« Reply #25 on: April 28, 2014, 07:06:34 AM »
Pedro, as we where kind enough to post possible solutions for you to use, please post your final solution here.
« Reply #26 on: April 28, 2014, 06:15:28 PM »
I try my best  :-)
I would recommend first verifying that your acaddoc.lsp is loading successfully -
Add a simple princ call to the very top of your acaddoc.lsp, e.g.:
(princ "\nacaddoc.lsp loaded.")
Then check that this message appears at the command-line when a drawing is opened.
irneb
« Reply #27 on: April 29, 2014, 03:31:49 AM »
Are you using ACadDoc.LSP or an MNL file?
If the ACadDoc.LSP is it on your support folder paths? What happens if you type this at the command prompt?
(findfile "acaddoc.lsp")If nil, the AutoCad can't find it, if it's shown in another folder, then you have 2 or more of them - AutoCAD only loads the 1st one it finds.
If the MNL is the accompanying CUI loaded? Are they both in the same folder and named the same?
