Client wants color coded areas of a site showing one color for cuts and one for fill areas.
With inroads we've developed a isopatch surface showing the dif in elev between exist and proposed surfaces. When generating a isopatch surface and staking we can use very small, close together text to appear like shaded areas when zoomed out, (yeah cheesy, but.....). I'm assuming a program that can color code cut/fill staking should be able to color code the triangels in a surface, cut/fill.
Is there a way to color code the triangles of a surface to show areas of cut and areas of fill?
Not to be confused with color coding elevation ranges (ie el 100 - 200 red, 200 - 300 yellow, etc). Thats going to show straight level cube like shapes
