Author Topic: ZoomPrevious in Pure ObjectARX code  (Read 1550 times)
cannorth
« on: March 04, 2014, 09:51:11 PM »
Hello,
  I'd  like to know if there is code for a purely ObjectARX ZoomPrevious method from AutoCAD's COM API?
Thanks,
cannorth
MickD
Re: ZoomPrevious in Pure ObjectARX code
« Reply #1 on: March 05, 2014, 12:55:50 AM »
save yourself the headache:
acadDoc.SendStringToExecute("ZOOM p\n", false, false, false);
While it might seem like a hack, you are implementing it fast and safely avoiding possibly buggy code to do something that acad could probably do quicker albeit in a roundabout way.
- John Carmack
- J.R.R. Tolkien
« Reply #2 on: March 05, 2014, 01:28:21 AM »
interestingly, AutoDesk use a similar code in their ARX samples
Code - C++: [Select]
  1. acedCommand(RTSTR, _T("_ZOOM"), RTSTR, _T("_Extents"), 0);    // zoom to a reasonable spot
