Author Topic: Customize double click action for Mleaders  (Read 1461 times)
BazzaCAD
« on: December 13, 2013, 01:44:37 PM »
I'd like to change the command that is run when you double click on a Mleader object.
This works fine when you double click on the leader segment, but doesn't work when you double click on the text.
Any suggestions on how to get this to work for both?
See attached vid.
