Author Topic: Why can not I see the objects in this file?  (Read 1984 times)
HasanCAD
« on: December 06, 2012, 12:19:46 AM »
Re: Why can not I see the objects in this file?
« Reply #1 on: December 06, 2012, 05:54:34 AM »
 How do you know there are objects in the file?
If you can not see them....
I only see one LWPOLYLINE, to me there is only one OBJECT in the file, not multiple objects.
Rob...
« Reply #2 on: December 06, 2012, 06:58:57 AM »
Use the force, Luke. Use the force.
Ctrl+A reveals a number of objects, a few of which go away after purging. I wish I had more time to play with it but I'll be watching for the solution.
CAD Tech
Jeff H
« Reply #3 on: December 06, 2012, 07:15:54 AM »
Not much time either but snooping it there are blockreferences with entites with their visible property set to false.
Got it to show a little something by using
Select - All
Change to layer zero
SetByLayer
Select-All
Select-All
Xplode
donnyvz
« Reply #4 on: December 07, 2012, 01:14:30 PM »
Did a recover which erased 12 objects and dwg now shows what Jeff H sees.
Did a dxfout (saveas) to ACAD2000 dxf then did a dxfin and I see dead peo.... err walls and windows etc., but still a lot of objects not visible.
Did an export all blocks in dwg to a folder and found 20 blocks, some visible some not, some containing other blocks in various states of visibility.
Basically, objects are flagged as INVISIBLE.
See http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=11938240&linkID=9240617 for more info and download and run the mi.lsp. You'll need to run it inside some blocks also and reinsert since it doesn't turn everything visible in TEST.dwg.
Good challenge!! /solved
« Reply #5 on: December 10, 2012, 04:57:05 AM »
solved
I think the person posting the issue is the only one that can declare that the issue is resolved.
