Author Topic: Get RGB indexes  (Read 1783 times)
Andrey Bushman
Get RGB indexes
« on: October 22, 2012, 08:27:54 AM »
I wrote such code:
StringBuilder sb = new StringBuilder();
sb.AppendLine("Index = R, G, B");
Int16 i;
for (i = 0; i < 256; ++i ) {
// get color by index
Autodesk.AutoCAD.Colors.Color color =
        Autodesk.AutoCAD.Colors.Color.FromColorIndex(AcCol.ColorMethod.None, i);
Byte r = color.Red;
Byte g = color.Green;
Byte b = color.Blue;
sb.AppendLine(String.Format("{0} = {1}, {2}, {3}", i, r, g, b));
String result = sb.ToString();
But I got strange result:
Index = R, G, B
0 = 0, 0, 0
1 = 0, 0, 1
2 = 0, 0, 2
3 = 0, 0, 3
4 = 0, 0, 4
5 = 0, 0, 5
6 = 0, 0, 6
7 = 0, 0, 7
8 = 0, 0, 8
9 = 0, 0, 9
10 = 0, 0, 10
11 = 0, 0, 11
12 = 0, 0, 12
13 = 0, 0, 13
14 = 0, 0, 14
15 = 0, 0, 15
16 = 0, 0, 16
17 = 0, 0, 17
18 = 0, 0, 18
19 = 0, 0, 19
20 = 0, 0, 20
21 = 0, 0, 21
22 = 0, 0, 22
23 = 0, 0, 23
24 = 0, 0, 24
25 = 0, 0, 25
26 = 0, 0, 26
27 = 0, 0, 27
28 = 0, 0, 28
29 = 0, 0, 29
30 = 0, 0, 30
31 = 0, 0, 31
32 = 0, 0, 32
33 = 0, 0, 33
34 = 0, 0, 34
35 = 0, 0, 35
36 = 0, 0, 36
37 = 0, 0, 37
38 = 0, 0, 38
39 = 0, 0, 39
40 = 0, 0, 40
41 = 0, 0, 41
42 = 0, 0, 42
43 = 0, 0, 43
44 = 0, 0, 44
45 = 0, 0, 45
46 = 0, 0, 46
47 = 0, 0, 47
48 = 0, 0, 48
49 = 0, 0, 49
50 = 0, 0, 50
51 = 0, 0, 51
52 = 0, 0, 52
53 = 0, 0, 53
54 = 0, 0, 54
55 = 0, 0, 55
56 = 0, 0, 56
57 = 0, 0, 57
58 = 0, 0, 58
59 = 0, 0, 59
60 = 0, 0, 60
61 = 0, 0, 61
62 = 0, 0, 62
63 = 0, 0, 63
64 = 0, 0, 64
65 = 0, 0, 65
66 = 0, 0, 66
67 = 0, 0, 67
68 = 0, 0, 68
69 = 0, 0, 69
70 = 0, 0, 70
71 = 0, 0, 71
72 = 0, 0, 72
73 = 0, 0, 73
74 = 0, 0, 74
75 = 0, 0, 75
76 = 0, 0, 76
77 = 0, 0, 77
78 = 0, 0, 78
79 = 0, 0, 79
80 = 0, 0, 80
81 = 0, 0, 81
82 = 0, 0, 82
83 = 0, 0, 83
84 = 0, 0, 84
85 = 0, 0, 85
86 = 0, 0, 86
87 = 0, 0, 87
88 = 0, 0, 88
89 = 0, 0, 89
90 = 0, 0, 90
91 = 0, 0, 91
92 = 0, 0, 92
93 = 0, 0, 93
94 = 0, 0, 94
95 = 0, 0, 95
96 = 0, 0, 96
97 = 0, 0, 97
98 = 0, 0, 98
99 = 0, 0, 99
100 = 0, 0, 100
101 = 0, 0, 101
102 = 0, 0, 102
103 = 0, 0, 103
104 = 0, 0, 104
105 = 0, 0, 105
106 = 0, 0, 106
107 = 0, 0, 107
108 = 0, 0, 108
109 = 0, 0, 109
110 = 0, 0, 110
111 = 0, 0, 111
112 = 0, 0, 112
113 = 0, 0, 113
114 = 0, 0, 114
115 = 0, 0, 115
116 = 0, 0, 116
117 = 0, 0, 117
118 = 0, 0, 118
119 = 0, 0, 119
120 = 0, 0, 120
121 = 0, 0, 121
122 = 0, 0, 122
123 = 0, 0, 123
124 = 0, 0, 124
125 = 0, 0, 125
126 = 0, 0, 126
127 = 0, 0, 127
128 = 0, 0, 128
129 = 0, 0, 129
130 = 0, 0, 130
131 = 0, 0, 131
132 = 0, 0, 132
133 = 0, 0, 133
134 = 0, 0, 134
135 = 0, 0, 135
136 = 0, 0, 136
137 = 0, 0, 137
138 = 0, 0, 138
139 = 0, 0, 139
140 = 0, 0, 140
141 = 0, 0, 141
142 = 0, 0, 142
143 = 0, 0, 143
144 = 0, 0, 144
145 = 0, 0, 145
146 = 0, 0, 146
147 = 0, 0, 147
148 = 0, 0, 148
149 = 0, 0, 149
150 = 0, 0, 150
151 = 0, 0, 151
152 = 0, 0, 152
153 = 0, 0, 153
154 = 0, 0, 154
155 = 0, 0, 155
156 = 0, 0, 156
157 = 0, 0, 157
158 = 0, 0, 158
159 = 0, 0, 159
160 = 0, 0, 160
161 = 0, 0, 161
162 = 0, 0, 162
163 = 0, 0, 163
164 = 0, 0, 164
165 = 0, 0, 165
166 = 0, 0, 166
167 = 0, 0, 167
168 = 0, 0, 168
169 = 0, 0, 169
170 = 0, 0, 170
171 = 0, 0, 171
172 = 0, 0, 172
173 = 0, 0, 173
174 = 0, 0, 174
175 = 0, 0, 175
176 = 0, 0, 176
177 = 0, 0, 177
178 = 0, 0, 178
179 = 0, 0, 179
180 = 0, 0, 180
181 = 0, 0, 181
182 = 0, 0, 182
183 = 0, 0, 183
184 = 0, 0, 184
185 = 0, 0, 185
186 = 0, 0, 186
187 = 0, 0, 187
188 = 0, 0, 188
189 = 0, 0, 189
190 = 0, 0, 190
191 = 0, 0, 191
192 = 0, 0, 192
193 = 0, 0, 193
194 = 0, 0, 194
195 = 0, 0, 195
196 = 0, 0, 196
197 = 0, 0, 197
198 = 0, 0, 198
199 = 0, 0, 199
200 = 0, 0, 200
201 = 0, 0, 201
202 = 0, 0, 202
203 = 0, 0, 203
204 = 0, 0, 204
205 = 0, 0, 205
206 = 0, 0, 206
207 = 0, 0, 207
208 = 0, 0, 208
209 = 0, 0, 209
210 = 0, 0, 210
211 = 0, 0, 211
212 = 0, 0, 212
213 = 0, 0, 213
214 = 0, 0, 214
215 = 0, 0, 215
216 = 0, 0, 216
217 = 0, 0, 217
218 = 0, 0, 218
219 = 0, 0, 219
220 = 0, 0, 220
221 = 0, 0, 221
222 = 0, 0, 222
223 = 0, 0, 223
224 = 0, 0, 224
225 = 0, 0, 225
226 = 0, 0, 226
227 = 0, 0, 227
228 = 0, 0, 228
229 = 0, 0, 229
230 = 0, 0, 230
231 = 0, 0, 231
232 = 0, 0, 232
233 = 0, 0, 233
234 = 0, 0, 234
235 = 0, 0, 235
236 = 0, 0, 236
237 = 0, 0, 237
238 = 0, 0, 238
239 = 0, 0, 239
240 = 0, 0, 240
241 = 0, 0, 241
242 = 0, 0, 242
243 = 0, 0, 243
244 = 0, 0, 244
245 = 0, 0, 245
246 = 0, 0, 246
247 = 0, 0, 247
248 = 0, 0, 248
249 = 0, 0, 249
250 = 0, 0, 250
251 = 0, 0, 251
252 = 0, 0, 252
253 = 0, 0, 253
254 = 0, 0, 254
255 = 0, 0, 255
Why I got 0 indexes for Red and Green?
gile
  • Marseille, France
Re: Get RGB indexes
« Reply #1 on: October 22, 2012, 09:06:49 AM »
Try with Color.ColorValue
Code - C#: [Select]
  1.         private int[,] GetTrueColorList()
  2.         {
  3.             int[,] result = new int[256,4];
  4.             for (short i = 1; i < 256; i++)
  5.             {
  6.                 Color c = Color.FromColorIndex(ColorMethod.ByAci, i);
  7.                 int r = c.ColorValue.R;
  8.                 int g = c.ColorValue.G;
  9.                 int b = c.ColorValue.B;
  10.                 result[i, 0] = r;
  11.                 result[i, 1] = g;
  12.                 result[i, 2] = b;
  13.                 result[i, 3] = (r << 16) + (g << 8) + b;
  14.             }
  15.             return result;
  16.         }
Index   1 = 255   0   0 (TrueColor: 16711680)
Index   2 = 255 255   0 (TrueColor: 16776960)
Index   3 =   0 255   0 (TrueColor:    65280)
Index   4 =   0 255 255 (TrueColor:    65535)
Index   5 =   0   0 255 (TrueColor:      255)
Index   6 = 255   0 255 (TrueColor: 16711935)
Index   7 = 255 255 255 (TrueColor: 16777215)
Index   8 = 128 128 128 (TrueColor:  8421504)
Index   9 = 192 192 192 (TrueColor: 12632256)
Index  10 = 255   0   0 (TrueColor: 16711680)
Index  11 = 255 127 127 (TrueColor: 16744319)
Index  12 = 165   0   0 (TrueColor: 10813440)
Index  13 = 165  82  82 (TrueColor: 10834514)
Index  14 = 127   0   0 (TrueColor:  8323072)
Index  15 = 127  63  63 (TrueColor:  8339263)
Index  16 =  76   0   0 (TrueColor:  4980736)
Index  17 =  76  38  38 (TrueColor:  4990502)
Index  18 =  38   0   0 (TrueColor:  2490368)
Index  19 =  38  19  19 (TrueColor:  2495251)
Index  20 = 255  63   0 (TrueColor: 16727808)
Index  21 = 255 159 127 (TrueColor: 16752511)
Index  22 = 165  41   0 (TrueColor: 10823936)
Index  23 = 165 103  82 (TrueColor: 10839890)
Index  24 = 127  31   0 (TrueColor:  8331008)
Index  25 = 127  79  63 (TrueColor:  8343359)
Index  26 =  76  19   0 (TrueColor:  4985600)
Index  27 =  76  47  38 (TrueColor:  4992806)
Index  28 =  38   9   0 (TrueColor:  2492672)
Index  29 =  38  23  19 (TrueColor:  2496275)
Index  30 = 255 127   0 (TrueColor: 16744192)
Index  31 = 255 191 127 (TrueColor: 16760703)
Index  32 = 165  82   0 (TrueColor: 10834432)
Index  33 = 165 124  82 (TrueColor: 10845266)
Index  34 = 127  63   0 (TrueColor:  8339200)
Index  35 = 127  95  63 (TrueColor:  8347455)
Index  36 =  76  38   0 (TrueColor:  4990464)
Index  37 =  76  57  38 (TrueColor:  4995366)
Index  38 =  38  19   0 (TrueColor:  2495232)
Index  39 =  38  28  19 (TrueColor:  2497555)
Index  40 = 255 191   0 (TrueColor: 16760576)
Index  41 = 255 223 127 (TrueColor: 16768895)
Index  42 = 165 124   0 (TrueColor: 10845184)
Index  43 = 165 145  82 (TrueColor: 10850642)
Index  44 = 127  95   0 (TrueColor:  8347392)
Index  45 = 127 111  63 (TrueColor:  8351551)
Index  46 =  76  57   0 (TrueColor:  4995328)
Index  47 =  76  66  38 (TrueColor:  4997670)
Index  48 =  38  28   0 (TrueColor:  2497536)
Index  49 =  38  33  19 (TrueColor:  2498835)
Index  50 = 255 255   0 (TrueColor: 16776960)
Index  51 = 255 255 127 (TrueColor: 16777087)
Index  52 = 165 165   0 (TrueColor: 10855680)
Index  53 = 165 165  82 (TrueColor: 10855762)
Index  54 = 127 127   0 (TrueColor:  8355584)
Index  55 = 127 127  63 (TrueColor:  8355647)
Index  56 =  76  76   0 (TrueColor:  5000192)
Index  57 =  76  76  38 (TrueColor:  5000230)
Index  58 =  38  38   0 (TrueColor:  2500096)
Index  59 =  38  38  19 (TrueColor:  2500115)
Index  60 = 191 255   0 (TrueColor: 12582656)
Index  61 = 223 255 127 (TrueColor: 14679935)
Index  62 = 124 165   0 (TrueColor:  8168704)
Index  63 = 145 165  82 (TrueColor:  9545042)
Index  64 =  95 127   0 (TrueColor:  6258432)
Index  65 = 111 127  63 (TrueColor:  7307071)
Index  66 =  57  76   0 (TrueColor:  3755008)
Index  67 =  66  76  38 (TrueColor:  4344870)
Index  68 =  28  38   0 (TrueColor:  1844736)
Index  69 =  33  38  19 (TrueColor:  2172435)
Index  70 = 127 255   0 (TrueColor:  8388352)
Index  71 = 191 255 127 (TrueColor: 12582783)
Index  72 =  82 165   0 (TrueColor:  5416192)
Index  73 = 124 165  82 (TrueColor:  8168786)
Index  74 =  63 127   0 (TrueColor:  4161280)
Index  75 =  95 127  63 (TrueColor:  6258495)
Index  76 =  38  76   0 (TrueColor:  2509824)
Index  77 =  57  76  38 (TrueColor:  3755046)
Index  78 =  19  38   0 (TrueColor:  1254912)
Index  79 =  28  38  19 (TrueColor:  1844755)
Index  80 =  63 255   0 (TrueColor:  4194048)
Index  81 = 159 255 127 (TrueColor: 10485631)
Index  82 =  41 165   0 (TrueColor:  2729216)
Index  83 = 103 165  82 (TrueColor:  6792530)
Index  84 =  31 127   0 (TrueColor:  2064128)
Index  85 =  79 127  63 (TrueColor:  5209919)
Index  86 =  19  76   0 (TrueColor:  1264640)
Index  87 =  47  76  38 (TrueColor:  3099686)
Index  88 =   9  38   0 (TrueColor:   599552)
Index  89 =  23  38  19 (TrueColor:  1517075)
Index  90 =   0 255   0 (TrueColor:    65280)
Index  91 = 127 255 127 (TrueColor:  8388479)
Index  92 =   0 165   0 (TrueColor:    42240)
Index  93 =  82 165  82 (TrueColor:  5416274)
Index  94 =   0 127   0 (TrueColor:    32512)
Index  95 =  63 127  63 (TrueColor:  4161343)
Index  96 =   0  76   0 (TrueColor:    19456)
Index  97 =  38  76  38 (TrueColor:  2509862)
Index  98 =   0  38   0 (TrueColor:     9728)
Index  99 =  19  38  19 (TrueColor:  1254931)
Index 100 =   0 255  63 (TrueColor:    65343)
Index 101 = 127 255 159 (TrueColor:  8388511)
Index 102 =   0 165  41 (TrueColor:    42281)
Index 103 =  82 165 103 (TrueColor:  5416295)
Index 104 =   0 127  31 (TrueColor:    32543)
Index 105 =  63 127  79 (TrueColor:  4161359)
Index 106 =   0  76  19 (TrueColor:    19475)
Index 107 =  38  76  47 (TrueColor:  2509871)
Index 108 =   0  38   9 (TrueColor:     9737)
Index 109 =  19  38  23 (TrueColor:  1254935)
Index 110 =   0 255 127 (TrueColor:    65407)
Index 111 = 127 255 191 (TrueColor:  8388543)
Index 112 =   0 165  82 (TrueColor:    42322)
Index 113 =  82 165 124 (TrueColor:  5416316)
Index 114 =   0 127  63 (TrueColor:    32575)
Index 115 =  63 127  95 (TrueColor:  4161375)
Index 116 =   0  76  38 (TrueColor:    19494)
Index 117 =  38  76  57 (TrueColor:  2509881)
Index 118 =   0  38  19 (TrueColor:     9747)
Index 119 =  19  38  28 (TrueColor:  1254940)
Index 120 =   0 255 191 (TrueColor:    65471)
Index 121 = 127 255 223 (TrueColor:  8388575)
Index 122 =   0 165 124 (TrueColor:    42364)
Index 123 =  82 165 145 (TrueColor:  5416337)
Index 124 =   0 127  95 (TrueColor:    32607)
Index 125 =  63 127 111 (TrueColor:  4161391)
Index 126 =   0  76  57 (TrueColor:    19513)
Index 127 =  38  76  66 (TrueColor:  2509890)
Index 128 =   0  38  28 (TrueColor:     9756)
Index 129 =  19  38  33 (TrueColor:  1254945)
Index 130 =   0 255 255 (TrueColor:    65535)
Index 131 = 127 255 255 (TrueColor:  8388607)
Index 132 =   0 165 165 (TrueColor:    42405)
Index 133 =  82 165 165 (TrueColor:  5416357)
Index 134 =   0 127 127 (TrueColor:    32639)
Index 135 =  63 127 127 (TrueColor:  4161407)
Index 136 =   0  76  76 (TrueColor:    19532)
Index 137 =  38  76  76 (TrueColor:  2509900)
Index 138 =   0  38  38 (TrueColor:     9766)
Index 139 =  19  38  38 (TrueColor:  1254950)
Index 140 =   0 191 255 (TrueColor:    49151)
Index 141 = 127 223 255 (TrueColor:  8380415)
Index 142 =   0 124 165 (TrueColor:    31909)
Index 143 =  82 145 165 (TrueColor:  5411237)
Index 144 =   0  95 127 (TrueColor:    24447)
Index 145 =  63 111 127 (TrueColor:  4157311)
Index 146 =   0  57  76 (TrueColor:    14668)
Index 147 =  38  66  76 (TrueColor:  2507340)
Index 148 =   0  28  38 (TrueColor:     7206)
Index 149 =  19  33  38 (TrueColor:  1253670)
Index 150 =   0 127 255 (TrueColor:    32767)
Index 151 = 127 191 255 (TrueColor:  8372223)
Index 152 =   0  82 165 (TrueColor:    21157)
Index 153 =  82 124 165 (TrueColor:  5405861)
Index 154 =   0  63 127 (TrueColor:    16255)
Index 155 =  63  95 127 (TrueColor:  4153215)
Index 156 =   0  38  76 (TrueColor:     9804)
Index 157 =  38  57  76 (TrueColor:  2505036)
Index 158 =   0  19  38 (TrueColor:     4902)
Index 159 =  19  28  38 (TrueColor:  1252390)
Index 160 =   0  63 255 (TrueColor:    16383)
Index 161 = 127 159 255 (TrueColor:  8364031)
Index 162 =   0  41 165 (TrueColor:    10661)
Index 163 =  82 103 165 (TrueColor:  5400485)
Index 164 =   0  31 127 (TrueColor:     8063)
Index 165 =  63  79 127 (TrueColor:  4149119)
Index 166 =   0  19  76 (TrueColor:     4940)
Index 167 =  38  47  76 (TrueColor:  2502476)
Index 168 =   0   9  38 (TrueColor:     2342)
Index 169 =  19  23  38 (TrueColor:  1251110)
Index 170 =   0   0 255 (TrueColor:      255)
Index 171 = 127 127 255 (TrueColor:  8355839)
Index 172 =   0   0 165 (TrueColor:      165)
Index 173 =  82  82 165 (TrueColor:  5395109)
Index 174 =   0   0 127 (TrueColor:      127)
Index 175 =  63  63 127 (TrueColor:  4145023)
Index 176 =   0   0  76 (TrueColor:       76)
Index 177 =  38  38  76 (TrueColor:  2500172)
Index 178 =   0   0  38 (TrueColor:       38)
Index 179 =  19  19  38 (TrueColor:  1250086)
Index 180 =  63   0 255 (TrueColor:  4129023)
Index 181 = 159 127 255 (TrueColor: 10452991)
Index 182 =  41   0 165 (TrueColor:  2687141)
Index 183 = 103  82 165 (TrueColor:  6771365)
Index 184 =  31   0 127 (TrueColor:  2031743)
Index 185 =  79  63 127 (TrueColor:  5193599)
Index 186 =  19   0  76 (TrueColor:  1245260)
Index 187 =  47  38  76 (TrueColor:  3089996)
Index 188 =   9   0  38 (TrueColor:   589862)
Index 189 =  23  19  38 (TrueColor:  1512230)
Index 190 = 127   0 255 (TrueColor:  8323327)
Index 191 = 191 127 255 (TrueColor: 12550143)
Index 192 =  82   0 165 (TrueColor:  5374117)
Index 193 = 124  82 165 (TrueColor:  8147621)
Index 194 =  63   0 127 (TrueColor:  4128895)
Index 195 =  95  63 127 (TrueColor:  6242175)
Index 196 =  38   0  76 (TrueColor:  2490444)
Index 197 =  57  38  76 (TrueColor:  3745356)
Index 198 =  19   0  38 (TrueColor:  1245222)
Index 199 =  28  19  38 (TrueColor:  1839910)
Index 200 = 191   0 255 (TrueColor: 12517631)
Index 201 = 223 127 255 (TrueColor: 14647295)
Index 202 = 124   0 165 (TrueColor:  8126629)
Index 203 = 145  82 165 (TrueColor:  9523877)
Index 204 =  95   0 127 (TrueColor:  6226047)
Index 205 = 111  63 127 (TrueColor:  7290751)
Index 206 =  57   0  76 (TrueColor:  3735628)
Index 207 =  66  38  76 (TrueColor:  4335180)
Index 208 =  28   0  38 (TrueColor:  1835046)
Index 209 =  33  19  38 (TrueColor:  2167590)
Index 210 = 255   0 255 (TrueColor: 16711935)
Index 211 = 255 127 255 (TrueColor: 16744447)
Index 212 = 165   0 165 (TrueColor: 10813605)
Index 213 = 165  82 165 (TrueColor: 10834597)
Index 214 = 127   0 127 (TrueColor:  8323199)
Index 215 = 127  63 127 (TrueColor:  8339327)
Index 216 =  76   0  76 (TrueColor:  4980812)
Index 217 =  76  38  76 (TrueColor:  4990540)
Index 218 =  38   0  38 (TrueColor:  2490406)
Index 219 =  38  19  38 (TrueColor:  2495270)
Index 220 = 255   0 191 (TrueColor: 16711871)
Index 221 = 255 127 223 (TrueColor: 16744415)
Index 222 = 165   0 124 (TrueColor: 10813564)
Index 223 = 165  82 145 (TrueColor: 10834577)
Index 224 = 127   0  95 (TrueColor:  8323167)
Index 225 = 127  63 111 (TrueColor:  8339311)
Index 226 =  76   0  57 (TrueColor:  4980793)
Index 227 =  76  38  66 (TrueColor:  4990530)
Index 228 =  38   0  28 (TrueColor:  2490396)
Index 229 =  38  19  33 (TrueColor:  2495265)
Index 230 = 255   0 127 (TrueColor: 16711807)
Index 231 = 255 127 191 (TrueColor: 16744383)
Index 232 = 165   0  82 (TrueColor: 10813522)
Index 233 = 165  82 124 (TrueColor: 10834556)
Index 234 = 127   0  63 (TrueColor:  8323135)
Index 235 = 127  63  95 (TrueColor:  8339295)
Index 236 =  76   0  38 (TrueColor:  4980774)
Index 237 =  76  38  57 (TrueColor:  4990521)
Index 238 =  38   0  19 (TrueColor:  2490387)
Index 239 =  38  19  28 (TrueColor:  2495260)
Index 240 = 255   0  63 (TrueColor: 16711743)
Index 241 = 255 127 159 (TrueColor: 16744351)
Index 242 = 165   0  41 (TrueColor: 10813481)
Index 243 = 165  82 103 (TrueColor: 10834535)
Index 244 = 127   0  31 (TrueColor:  8323103)
Index 245 = 127  63  79 (TrueColor:  8339279)
Index 246 =  76   0  19 (TrueColor:  4980755)
Index 247 =  76  38  47 (TrueColor:  4990511)
Index 248 =  38   0   9 (TrueColor:  2490377)
Index 249 =  38  19  23 (TrueColor:  2495255)
Index 250 =   0   0   0 (TrueColor:        0)
Index 251 =  51  51  51 (TrueColor:  3355443)
Index 252 = 102 102 102 (TrueColor:  6710886)
Index 253 = 153 153 153 (TrueColor: 10066329)
Index 254 = 204 204 204 (TrueColor: 13421772)
Index 255 = 255 255 255 (TrueColor: 16777215)
Andrey Bushman
Re: Get RGB indexes
« Reply #2 on: October 22, 2012, 09:14:56 AM »
2 gile
Yes, I did it here too.
It is interesting for me: why Color by AutoCAD has other RGB values, not the same as its System.Drawing.Color original?
