Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Find known object inside a block
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Find known object inside a block (Read 1548 times)
kenkrupa
Newt
WWW
on:
November 27, 2013, 03:27:29 PM »
Some dynamic blocks each contain a circle. For any insertion of that block, I want to find the center point of that circle. It will always lie in the World plane, but it's relation to the insertion point varies when a dynamic angle changes. I need to find the center of this circle. Any way to do this?
Logged
Seagull
London, England
WWW
Re: Find known object inside a block
Reply #1 on:
November 27, 2013, 06:48:57 PM »
You should be able to use the center of the circle found within the anonymous block definition that is automatically generated for the dynamic block reference when the dynamic parameters are altered.
You would then transform the center coordinates to account for the block reference position, scale & rotation using an appropriate transformation matrix - for this I would recommend gile's
refgeom
function.
Logged
Lee Mac Programming
Twitter
Exchange App Store
kenkrupa
Newt
WWW
Reply #2 on:
November 27, 2013, 10:22:16 PM »
Thank you much Lee, and gile too. That matrix stuff is something I would never figure out myself. Going into Thanksgiving day here, so it may be a few days before I can apply this, but I'm thankful for it already!
Logged
Seagull
London, England
WWW
Reply #3 on:
November 28, 2013, 09:38:29 AM »
You're most welcome ken
Here is a quick & simple example program for you to test:
Code - Auto/Visual Lisp:
[Select]
defun
c:cc
blk bln blx cen ent enx lst
while
progn
setvar
'errno
0
setq
blk
car
entsel
\n
Select block: "
cen
nil
cond
7
getvar
'errno
princ
\n
Missed, try again."
null
blk
nil
"INSERT"
cdr
assoc
0
setq
blx
entget
blk
princ
\n
Please select a block."
not
or
setq
bln
cdr
assoc
2
blx
cen
cdr
assoc
bln lst
progn
setq
ent
tblobjname
"block"
bln
while
and
null
cen
setq
ent
entnext
ent
if
"CIRCLE"
cdr
assoc
0
setq
enx
entget
ent
setq
cen
trans
cdr
assoc
10
enx
cdr
assoc
210
enx
0
if
cen
setq
lst
cons
cons
bln cen
lst
princ
\n
Selected block does not contain a circle."
entmake
list
0
"POINT"
cons
10
apply
lambda
m v
mapcar
mxv m cen
v
refgeom blk
princ
;; RefGeom (gile)
;; Returns a list whose first item is a 3x3 transformation matrix and
;; second item the object insertion point in its parent (xref, block or space)
defun
refgeom
ent
ang enx mat ocs
setq
enx
entget
ent
ang
cdr
assoc
050 enx
ocs
cdr
assoc
210
enx
list
setq
mat
mxm
mapcar
lambda
v
trans
v
0
ocs t
1.0
0.0
0.0
0.0
1.0
0.0
0.0
0.0
1.0
mxm
list
list
cos
ang
sin
ang
0.0
list
sin
ang
cos
ang
0.0
0.0
0.0
1.0
list
list
cdr
assoc
41
enx
0.0
0.0
list
0.0
cdr
assoc
42
enx
0.0
list
0.0
0.0
cdr
assoc
43
enx
mapcar
trans
cdr
assoc
10
enx
ocs
0
mxv mat
cdr
assoc
10
tblsearch
"block"
cdr
assoc
2
enx
;; Matrix Transpose - Doug Wilson
;; Args: m - nxn matrix
defun
trp
m
apply
mapcar
cons
list
m
;; Matrix x Matrix - Vladimir Nesterovsky
;; Args: m,n - nxn matrices
defun
mxm
m n
lambda
a
mapcar
lambda
r
mxv a r
m
trp n
;; Matrix x Vector - Vladimir Nesterovsky
;; Args: m - nxn matrix, v - vector in R^n
defun
mxv
m v
mapcar
lambda
r
apply
mapcar
r v
m
princ
The program will generate a
POINT
entity at the center of the first circle found in the block definition (this could easily be altered to match circles based on criteria such as layer / linetype / colour / handle etc.)
Here is a demonstration using a simple dynamic block with a dynamic move parameter assigned to the circle:
Last Edit: November 28, 2013, 09:41:34 AM by Lee Mac
Logged
Lee Mac Programming
Twitter
Exchange App Store
kenkrupa
Newt
WWW
Reply #4 on:
November 28, 2013, 10:35:31 AM »
Perfect! Thank you!
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
