Author Topic: VBA7 and C# scripting?  (Read 4668 times)
Jeff H
« on: June 19, 2012, 07:37:05 PM »
First I heard of VBA7.
Suprised I have not seen more people talk about it and if you google VBA7 a link with AutoCAD is like #4.
What is C# scripting? Do they mean using the DLR?
From AutoCAD API Wishlist Survey 2012
It's Alive!
  • Retired
  • AKA Daniel
Re: VBA7 and C# scripting?
« Reply #1 on: June 19, 2012, 07:41:49 PM »
it just won't die  :|
« Reply #2 on: June 19, 2012, 09:13:05 PM »
Jeff wash mouth with soap you do.
ps
There were a few things about the survey that assume the respondant has full knowledge of the options.
« Last Edit: June 19, 2012, 09:20:31 PM by Kerry »
« Reply #3 on: June 20, 2012, 12:53:52 AM »
Just an observation.
For the last several years the following have been high on the list ;
Improvement to Visual Lisp.
Improvement to API documentation.
The requirements/wishes of the development community are not necessarily listened to.
Lisual Lisp is essentially unchanged since it was purchased from Basis software (release 14)
.. except for having the interactive ActiveX documentation removed.
The Internet based help documentation for the .NET API is still for the AC2011 build
.. 2 versions behind.
... but I'll shut up before I get a reputation as a stirrer.
BlackBox
« Reply #4 on: June 20, 2012, 12:05:40 PM »
... You were:
LoL  :-P
dgorsman
« Reply #5 on: June 20, 2012, 01:08:12 PM »
ps
This one felt very much like a push poll...
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
