I have been doing some cutting and pasting of a lisp and dcl routine. And I wanted to know if anyone knew of a way I could modify it so, that when I pick a project and select ok it will open that projects template and also let me scale the viewport. The view port scale isn't all that important if it can't be done. Any help on this would be appreciated.
Here is the lsp:
(defun c:ProjectTemplate ()
(setvar "BLIPMODE" 0)
(setvar "CMDECHO" 0)
(setvar "OSMODE" 0)
(setq typ "e")
(setq dcl_id (load_dialog "ProjectTemplate.dcl"))
(if (not
(new_dialog "ProjectTemplate" dcl_id)
(exit)
(set_tile "rb1" "1")
(action_tile "rb1"
"(setq typ \"e\")
(mode_tile \"eb1\" 2) ")
(action_tile "rb2"
"(setq typ \"a\")
(action_tile "rb3"
"(setq typ \"c\")
(action_tile "rb4"
"(setq typ \"e1\")
(action_tile "rb5"
"(setq typ \"b\")
(action_tile "cancel"
"(done_dialog) (setq userclick nil) ")
(action_tile "accept"
(strcat
"(progn (setq #dwgsc
(atof (get_tile \"eb1\")))"
"(done_dialog) (setq userclick T))"
(start_dialog)
(unload_dialog dcl_id)
Here is the dcl:
ProjectTemplate : dialog {
label = "New Drawing Setup";
: row {
: boxed_radio_column {
label = "Choose Project";
: radio_button {
label = "&Project Name";
key = "rb1";
value = "1";
: radio_button {
key = "rb2";
: radio_button {
key = "rb3";
: radio_button {
label = "Project Name";
key = "rb4";
: radio_button {
key = "rb5";
: edit_box {
label = "&Enter Drawing Scale :" ;
key = "eb1" ;
edit_width = 8 ;
: spacer { width = 1;}
ok_cancel ;
: paragraph {
: text_part {
