I know I've seen this somewhere but can't find it.....
What I'm looking for is a routine that will allow me to set a number to start numbering from (5,6,7,) as well as set a prefix (A5,A6,A7,) for each. then be able to select blocks (one by one) with attributes in a certain order and the routine fills in the attribute with information in the order they were picked. (ie..first picked block is A5 second A6 and so on....).
The attribute tag name will always be LATERALID.
Thanks,
Ron
