Author Topic: Associative Array - Obtain the Row and Column Count  (Read 2073 times)
Xander
« on: April 14, 2011, 01:44:51 AM »
As the topic says, I'm attempting to pull the row and column count of the new fantastic associative arrays (perfect for carpark line marking!).
The problem I have, is.. ENTGET on the array returns a nice DXF list, but nothing with the row/column count.
Command: (ENTGET (CAR(ENTSEL)))
Select object: ((-1 . <Entity name: 7ffff1d5020>) (0 . "INSERT") (5 . "BAA")
(102 . "{ACAD_REACTORS") (330 . <Entity name: 7ffff1d52b0>) (102 . "}") (330 .
<Entity name: 7ffff3169f0>) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 .
"C-G-Line-Mark") (100 . "AcDbBlockReference") (2 . "*U31") (10 5286.93 3656.61
0.0) (41 . 1.0) (42 . 1.0) (43 . 1.0) (50 . 0.0) (70 . 0) (71 . 0) (44 . 0.0)
(45 . 0.0) (210 0.0 0.0 1.0))
Any ideas?
Xander
Re: Associative Array - Obtain the Row and Column Count
« Reply #1 on: April 14, 2011, 02:33:15 AM »
I recall reading somewhere that there was no lisp API for this feature.
I haven't tried yet with either lisp or .net
Crank
« Reply #2 on: April 14, 2011, 03:04:08 PM »
Any ideas?
Xander
Have you investigated the soft-pointer handles (DXF-code 330) ?
« Reply #3 on: April 14, 2011, 03:34:32 PM »
The extension dictionary?
Xander
« Reply #4 on: April 14, 2011, 06:26:12 PM »
Thanks Guys. I'll look into it when I get another chance.
