Author Topic: How to make the CAD command repeat? ? ?  (Read 2080 times)
xiaxiang
« on: December 07, 2010, 03:08:26 AM »
Opinion:
      No matter what kind of program, CAD command  is the most!But while running the command, but also cumbersome press Enter,
What will be a lot of mess, annoying .........
Request:
      Want to know how to repeat the CAD commands , can you leave a message, or help, thank you! ! !
      If you don't press the space,  the command will automatically jump in the back after the implementation,
 But when pressing the space it will automatically exit !
      Who can do this for me,thanks a lot!
(setq *g-var* nil)
(defun userselect (/ string1 string2 num n showstr char TextList)
  (setq string1 "\n asign next action:[action1(A)/action2(B)/action3(C)]action1(A):"
        string2 "\n asign next action:[action1(A)/action2(B)/action3(C)]action2(B):"
  (setq num 0)
  (while (< num 4)
    (if *g-var*
      (setq n *g-var*)
      (setq n 1)
      ((= n 1) (setq showstr string1))
      ((= n 2) (setq showstr string2))
    (setq char (getstring showstr)
          TextList (list (cons "A" 1)
                         (cons "a" 1)
                         (cons "" n)
                         (cons "B" 2)
                         (cons "b" 2)
                         (cons "C" 4)
                         (cons "c" 4)
    (if (assoc char TextList)
      (setq num (cdr (assoc char TextList)))
      (setq num 3)
    (if (< num 3)
      (setq *g-var* num)
      (if (> num 3)
        (setq *g-var* 1)
      ((= num 1) func1)
      ((= num 2) func2)
      ((= num 3) (princ "\n input valid,please input again."))
      ((= num 4) (princ))
« Last Edit: December 07, 2010, 03:28:57 AM by xiaxiang »
roy_043
  • BricsCAD 18
Re: How to make the CAD command repeat? ? ?
« Reply #1 on: December 07, 2010, 05:06:04 AM »
Why not use the command: MULTIPLE? :wink:
yarik
« Reply #2 on: December 07, 2010, 12:02:13 PM »
Hi Xiaxiang
Maybe you can use the cmdactive variable
Something like
(while  (= 1 (logand (getvar "CMDACTIVE") 1))
(yourfunction)
I don't know if works but it`s a idea
