Author Topic: Using attributes to populate mtext fields  (Read 1951 times)
Dommy2Hotty
« on: July 13, 2010, 06:50:15 PM »
Scenario:
I would like to use my Room Tag blocks that have visible (name and number) & invisible attributes (for room finishes) within them to populate mtext fields in a Room Finish Schedule.  I have completed this step.  The Room Finish Schedule has Fields that extract the attribute data FROM the Room Tags.
Problem:
I have to manually update each field and pick the same Room Tag for each field.
Solution sought:
Pick Room Tag to associate and extract attribute information to their proper fields.
I have no clue how to go about this...too involved?  Use tables? Any and all direction will be greatly appreciated.
Sample:
Re: Using attributes to populate mtext fields
« Reply #1 on: July 13, 2010, 07:39:44 PM »
Hi Dommy,
Perhaps this will make your life easier:
(defun c:Att2Field ( / *error* doc spc tables att atts undo pt str )
  ;; © Lee Mac 2010
  (defun *error* ( msg )
    (and undo (vla-EndUndoMark doc))
    (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
        (princ (strcat "\n** Error: " msg " **")))
  (LM:ActiveSpace 'doc 'spc)
  (setq tables (LM:ss->vla (ssget "_X" '((0 . "ACAD_TABLE")))))
  (if (setq att
        (LM:SelectifFoo
          (lambda ( x )
            (and (eq "INSERT" (cdr (assoc 0 (entget x))))
              (= 1 (cdr (assoc 66 (entget x))))
          "\nSelect Block to Retrieve Attribute Data: "
      (setq atts (vlax-invoke (vlax-ename->vla-object att) 'GetAttributes))
      (setq undo (not (vla-StartUndoMark doc)))
      (while (and (setq att (car atts))
                  (setq pt  (getpoint (strcat "\nPlace " (vla-get-TextString att) " : "))))
        (setq str  (strcat "%<\\AcObjProp Object(%<\\_ObjId " (LM:GetObjectID att doc) ">%).TextString>%")
              atts (cdr atts))
        (cond (  (LM:TextinCell tables pt str)  )
              (  (vla-AddMText spc (vlax-3D-point pt) 0 str)  ))
      (setq undo (vla-EndUndoMark doc))
;;-------------------=={ Text in Cell }==---------------------;;
;;  If specified point lies inside a table cell, cell text is ;;
;;  set to the specified string.                              ;;
;;  Author: Lee McDonnell, 2010                               ;;
;;  Copyright © 2010 by Lee McDonnell, All Rights Reserved.   ;;
;;  Contact: Lee Mac @ TheSwamp.org, CADTutor.net             ;;
;;  Arguments:                                                ;;
;;  tables - a list of VLA Table Objects to be checked        ;;
;;  pt     - a 3D Point                                       ;;
;;  str    - a string to populate the cell                    ;;
;;  Returns:  T if text is allocated into a cell, else nil    ;;
(defun LM:TextinCell ( tables pt str / data )
  ;; © Lee Mac 2010
    (setq data
      (vl-some
        (function
          (lambda ( table )
              (eq :vlax-true
                (vla-hittest table (vlax-3D-point (trans pt 1 0))
                  (vlax-3D-point (trans (getvar 'VIEWDIR) 1 0)) 'row 'col
              (list table row col)
        tables
    (not
      (apply (function vla-setText)
        (append data (list str))
;;-----------------=={ SelectionSet -> VLA }==----------------;;
;;  Converts a SelectionSet to a list of VLA Objects          ;;
;;  Arguments:                                                ;;
;;  ss - Valid SelectionSet (Pickset)                         ;;
;;  Returns:  List of VLA Objects                             ;;
(defun LM:ss->vla ( ss )
  ;; © Lee Mac 2010
  (if ss
      (lambda ( i / e l )
        (while (setq e (ssname ss (setq i (1+ i))))
          (setq l (cons (vlax-ename->vla-object e) l))
        l
      -1
;;-------------------=={ Select if Foo }==--------------------;;
;;  Continuous selection prompts until the predicate function ;;
;;  foo is validated                                          ;;
;;  Arguments:                                                ;;
;;  foo - predicate function taking ename argument            ;;
;;  str - prompt string                                       ;;
;;  Returns:  selected entity ename if successful, else nil   ;;
(defun LM:SelectifFoo ( foo str / sel ent )
  ;; © Lee Mac 2010
  (while
      (setq sel (entsel str))
          (vl-consp sel)
          (if (not (foo (setq ent (car sel))))
            (princ "\n** Invalid Object Selected **")
  ent
;;--------------------=={ Get ObjectID }==--------------------;;
;;  Returns the ObjectID string for the specified VLA Object  ;;
;;  Arguments:                                                ;;
;;  obj - VLA Object to process                               ;;
;;  doc - VLA Document Object                                 ;;
;;  Returns:  ObjectID String, else nil                       ;;
(defun LM:GetObjectID ( obj doc )
  ;; © Lee Mac 2010
  (if (eq "X64" (strcase (getenv "PROCESSOR_ARCHITECTURE")))
    (vlax-invoke-method (vla-get-Utility doc) 'GetObjectIdString obj :vlax-false)
    (itoa (vla-get-Objectid obj))
;;--------------------=={ ActiveSpace }==---------------------;;
;;  Retrieves pointers to the Active Document and Space       ;;
;;  Arguments:                                                ;;
;;  *doc - quoted symbol other than *doc                      ;;
;;  *spc - quoted symbol other than *spc                      ;;
(defun LM:ActiveSpace ( *doc *spc )
  ;; © Lee Mac 2010
  (set *spc
      (or
        (eq AcModelSpace
          (vla-get-ActiveSpace
            (set *doc
              (vla-get-ActiveDocument
                (vlax-get-acad-object)
        (eq :vlax-true (vla-get-MSpace (eval *doc)))
      (vla-get-ModelSpace (eval *doc))
      (vla-get-PaperSpace (eval *doc))
It will prompt for a selection of a block and gather all attribute data from within that block. It will then prompt you to place fields for each attribute either as MText or within a Table Cell.
Let me know how you get on,
Lee
Krushert
  • FREE BEER Tomorrow!!
« Reply #2 on: July 14, 2010, 10:36:02 AM »
Dommy,
Have you tried using Data Extraction Wizard?  You can have it create table at the end that is always linked to your Room Tags.  Any changes to any room tags including adding additional room tags are reflected upon updating the table.  And the link can jump across dwg files.   No need for feilds but you can include them if you want.
