Author Topic: -={ Challenge }=- is Prime  (Read 10422 times)
Re: -={ Challenge }=- is Prime
« Reply #30 on: September 22, 2010, 02:03:25 PM »
Looks like I'm going to have to take another look at my code  :|
« Reply #31 on: September 22, 2010, 02:24:05 PM »
(HFB:isPrime 2)
(HFB:isPrime 1)
« Reply #32 on: September 22, 2010, 02:30:14 PM »
Hopefully better  :oops:
(defun LM:isPrime ( p / i r f )
  ;; © Lee Mac 2010
  (if (or (= 2 p) (= 3 p)) T
      (setq i (fix (sqrt p))
            r (or (> 2 p) (zerop (rem p 2)) (zerop (rem p 3))) f -1)
      (while (and (not r) (<= (setq f (+ f 6)) i))
        (if (or (zerop (rem p f)) (zerop (rem p (+ f 2))))
          (setq r T)
      (not r)
Liked your loop control David :-)
« Reply #33 on: September 22, 2010, 02:34:58 PM »
Provided there aren't bugs (highly possible!)
Please enter a range(<100000000):1000
---- HFB ----
It takes 0.007 Seconds
The count of primes is: 168
---- DB ----
It takes 0.01 Seconds
---- LM -----
It takes 0.006 Seconds
Please enter a range(<100000000):10000
---- HFB ----
It takes 0.281 Seconds
The count of primes is: 1229
---- DB ----
It takes 0.34 Seconds
---- LM -----
It takes 0.21 Seconds
Please enter a range(<100000000):100000
---- HFB ----
It takes 6.783 Seconds
The count of primes is: 9592
---- DB ----
It takes 6.639 Seconds
---- LM -----
It takes 3.436 Seconds
David Bethel
« Reply #34 on: September 22, 2010, 03:37:39 PM »
(defun is_prime (i / r n s)
  (setq n 3
        s (sqrt i)
        r (cond ((/= (type i) 'INT) T)
                ((<= i 1)           T)
                ((= i 2)          nil)
                ((zerop (rem i 2))  T)))
  (while (and (not r)
              (<= n s))
         (if (zerop (rem i n))
             (setq r T)
             (setq n (+ n 2))))
  (not r))
Surprised me how much faster it is when you don't use the (sqrt) function each iteneration  -David
R12 Dos - A2K
« Reply #35 on: September 22, 2010, 05:43:04 PM »
Certainly improves the time David, the less calculated within the loop the better  :-)
---- HFB ----
---- DB ----
It takes 0.016 Seconds
---- LM -----
It takes 0.013 Seconds
---- HFB ----
It takes 0.184 Seconds
---- DB ----
It takes 0.228 Seconds
---- LM -----
It takes 0.147 Seconds
---- HFB ----
It takes 6.322 Seconds
---- DB ----
It takes 5.37 Seconds
---- LM -----
It takes 3.316 Seconds
Please enter a range(<100000000):200000
---- HFB ----
It takes 18.25 Seconds
The count of primes is: 17984
---- DB ----
It takes 15.028 Seconds
---- LM -----
It takes 8.587 Seconds
pkohut
« Reply #36 on: September 23, 2010, 10:22:45 AM »
A dollar short and a day late. Was in Python so...
def PrintIsPrime(x):
"""Determines if x is prime and prints result"""
s1 = "Is prime!"
s2 = "Is not prime!"
if x < 2 or (x > 2 and x % 2 == 0):
s = s2
elif x == 2:
s = s1
else:
i = 3
while x % i != 0:
i += 2
s = s1 if i == x else s2
print(x, s)
def IsPrime(x):
"""Returns True/False result of x == prime number"""
return False
elif x == 2:
return True
else:
i = 3
while x % i != 0:
i += 2
return True if i == x else False
>>> PrintIsPrime(3)
3 Is prime!
>>> PrintIsPrime(101)
101 Is prime!
>>> PrintIsPrime(100000001)
100000001 Is not prime!
>>> IsPrime(1508138953)
1508138953 Is prime!  <<<<-------That one took a minute or so to calc.
>>> IsPrime(3)
True
>>> IsPrime(3)
True
>>> IsPrime(21)
False
>>> IsPrime(31)
True
New tread (not retired) - public repo at https://github.com/pkohut
highflyingbird
  • Later equals never.
« Reply #37 on: September 23, 2010, 11:14:09 AM »
How about" Miller-Rabin primality test"?
when the number < 3.4X10^14 ,the result of test is correct.
static unsigned g_aPrimeList[] = { // 100素数表
        2, 3, 5, 7, 11, 13, 17, 19, 23, 29, 31, 37, 41,
43, 47, 53, 59, 61, 67, 71, 73, 79, 83, 89, 97
unsigned Montgomery(INT64 n,unsigned p,unsigned m)
{ //快速计算(n^e)%m的值
unsigned k=1;
n%=m;
while(p!=1)
if(0!=(p&1))
k=(k*n)%m;
n=(n*n)%m;
p>>=1;
return(n*k)%m;
bool RabbinMillerTest( unsigned n )
if (n<2)
{ // 小于2的数即不是合数也不是素数
throw 0;
const unsigned nPrimeListSize=sizeof(g_aPrimeList)/sizeof(unsigned);//求素数表元素个数
for(int i=0;i<nPrimeListSize;++i)
{// 按照素数表中的数对当前素数进行判断
if (n/2+1<=g_aPrimeList[i])
{// 如果已经小于当前素数表的数,则一定是素数
return true;
if (0==n%g_aPrimeList[i])
{// 余数为0则说明一定不是素数
return false;
// 找到r和m,使得n = 2^r * m + 1;
int r = 0, m = n - 1; // ( n - 1 ) 一定是合数
while ( 0 == ( m & 1 ) )
m >>= 1; // 右移一位
r++; // 统计右移的次数
const unsigned nTestCnt = 7; // 表示进行测试的次数
for ( unsigned i = 0; i < nTestCnt; ++i )
{ // 利用随机数进行测试,
int a = g_aPrimeList[ i ];
if ( 1 != Montgomery( a, m, n ) )
int j = 0;
int e = 1;
for ( ; j < r; ++j )
if ( n - 1 == Montgomery( a, m * e, n ) )
break;
e <<= 1;
if (j == r)
return false;
return true;
RabbinMillerTest (2234223321);
return 0;
because this way used "_int64",so it's not  applicable for LISP . but for a small number ,it's ok.
(defun paw_mod( bs power diver)
    ((zerop power)
     1
    ((= power 1)
     bs
    ((= (logand power 1) 0)
     (paw_mod (rem (* bs bs) diver) (lsh power -1) diver)
    (t
      (rem (* (paw_mod (rem (* bs bs) diver) (/ power 2) diver) bs) diver)
(defun RabbinMiller (base num / D K N RET TT)
  (setq n (1- num))
  (setq d n)
  (while (= (logand d 1) 0)
    (setq d (lsh d -1))
  (setq k (paw_mod base d num))
  (if (or (= k 1) (= k n))
    t
      (setq tt (/ n 2))
      (while (/= d tt)
(setq d (lsh d 1))
(if (= (paw_mod base d num) n)
  (setq ret t
d tt
ret
(defun check(p)
  (if (> p 13)
      ( (or (= (rem p 2) 0)
    (= (rem p 3) 0)
    (= (rem p 5) 0)
    (= (rem p 7) 0)
    (= (rem p 11) 0)
    (= (rem p 13) 0)
        nil
      ( (and (RabbinMiller 2 p)
     (RabbinMiller 7 p)
     (RabbinMiller 5 p)
        T
      (t nil)
    (and (member p '(2 3 5 7 11 13)))
(check 23421);
nil;
« Last Edit: September 23, 2010, 11:39:22 AM by highflybird »
I am a bilingualist,Chinese and Chinglish.
