Author Topic: Extend/Trim set of lines to a line  (Read 4792 times)
sinc
« on: December 24, 2004, 11:30:35 AM »
Some time back, I think someone posted a Lisp routine for extending/trimming a selection set of lines to a line, but I can't seem to find it.  Anyone got something that does that?  I'm pressed for time, and don't want to write one myself.
Dommy2Hotty
« Reply #1 on: December 24, 2004, 11:43:18 AM »
Extend
(defun C:EXTMULT (/ ss pt ls no edges)
;(f:modes)
        (prompt "\nSelect line to extend to..")
(setq edges (ssget))
(prompt "\nSelect object(s) to extend: ")
(setq ss (ssget)
pt (getpoint "\nSelect line to extend to: ")
ls (sslength ss)
no -1)
(command "extend" edges "")
(repeat ls
(setq no (1+ no))
(command (list (ssname ss no) pt))
(command "")
Trim
(defun C:TRIMMULT (/ ss pt ls no edges)
;(f:modes)
(prompt "\nSelect cutting edges..")
(prompt "\nSelect object(s) to trim: ")
(setq ss (ssget)
pt (getpoint "\nSide to trim: ")
ls (sslength ss)
no -1)
(command "trim" edges "")
(repeat ls
(setq no (1+ no))
(command "")
CADaver
Re: Extend/Trim set of lines to a line
« Reply #2 on: December 24, 2004, 01:14:49 PM »
Quote from: sinc
ummm... FENCE???
« Reply #3 on: December 24, 2004, 01:22:05 PM »
Sinc, where have you been?
Here is another:
(defun C:TRM (/ pt1 usrecho useros ss)
  (setq usrecho (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (setq useros (getvar "osmode"))
  (setvar "osmode" 0)
  (while
      (prompt "\nSelect cutting edges: ")
      (if (setq ss (ssget))
          (command "undo" "begin")
          (setq pt1 (getpoint "\nDraw line to select items to be trimmed: ") )
            ((/= pt1 nil)
             (not(command "_.trim" ss "" "F" pt1 pause "" ""))
            (T nil)
  (command "undo" "end")
  (setvar "cmdecho" usrecho)
  (setvar "osmode" useros)
) ; end defun
(princ "\nType TRM to run.")
qjchen
  • Best wishes to all
« Reply #4 on: June 15, 2010, 11:19:20 AM »
Just modify this topic to add a gif picture.
From Mr Stig Smadsen's homepage, I find the useful program to combine trim and extend  line in one.
http://intervision.hjem.wanadoo.dk/lisps/touch.lsp
I am not sure whether Mr Stig Smadsen has post here.:)
;;; Touch.LSP                                              *
;;; Small routine to align endpoints of lines to an edge.  *
;;; The edge have to be a line.                            *
;;; The routine works by calculating the point of inter-   *
;;; section and change the nearest endpoint to that point  *
;;; 2001 Stig Madsen, no rights reserved                   *
(defun C:Tt(/ cmd ent entl spt ept sset a lent lentl lspt lept lint)
  (setq cmd (getvar "CMDECHO"))
  (setvar "CMDECHO" 0)
  (command "UNDO" "Begin")
  (while (not ent)
    (setq ent (car (entsel "Select edge line: ")))
    (if ent
        (setq entl (entget ent))
        (if (/= (cdr (assoc 0 entl)) "LINE")
          (setq ent nil)
          (setq spt (cdr (assoc 10 entl))
                ept (cdr (assoc 11 entl))
  (if ent
      (redraw ent 3)
      (prompt "\nSelect lines to touch edge: ")
      (setq sset (ssget '((0 . "LINE")))
            a    0
      (if sset
        (repeat (sslength sset)
          (setq lentl (entget (setq lent (ssname sset a)))
                lspt  (cdr (assoc 10 lentl))
                lept  (cdr (assoc 11 lentl))
                lint  (inters spt ept lspt lept nil)
          (if lint
              (if (< (distance lint lspt) (distance lint lept))
                (entmod (subst (cons 10 lint) (assoc 10 lentl) lentl))
                (entmod (subst (cons 11 lint) (assoc 11 lentl) lentl))
          (setq a (1+ a))
        (princ "\nNo objects found")
      (redraw ent 4)
    (princ "\nNo edge selected")
  (setvar "CMDECHO" cmd)
  (command "UNDO" "End")
I do a little modification to enlarge the edge type extension, but the extend and trim object still must be lines
I can't write the code to let the extend and trim object also more than lines
;;; Touch.LSP                                              *
;;; modified by qjchen, the edge line can be line or polyline *
(defun C:Ttt (/ cmd ent entl spt ept sset a lent lentl lspt lept lint)
  (while (not ent)
    (if ent
  (if ent
      (redraw ent 3)
    a 0
      (if sset
  (setq entttt (ssname sset a))
  (setq lint (nth 0 (x_intlst ent entttt acExtendOtherEntity)))
  (if lint
(entmod (subst
  (cons 10 lint)
  (assoc 10 lentl)
  lentl
(entmod (subst
  (cons 11 lint)
  (assoc 11 lentl)
  lentl
  (setq a (1+ a))
      (redraw ent 4)
;;; by kuangdao at xdcad
(defun x_intlst (obj1 obj2 param / intlst1 intlst2 ptlst)
  (if (= 'ENAME (type obj1))
    (setq obj1 (vlax-ename->vla-object obj1))
  (if (= 'ENAME (type obj2))
    (setq obj2 (vlax-ename->vla-object obj2))
  (setq intlst1 (vlax-variant-value (vla-intersectwith obj1 obj2 param)))
  (if (< 0 (vlax-safearray-get-u-bound intlst1 1))
      (setq intlst2 (vlax-safearray->list intlst1))
      (while (> (length intlst2) 0)
(setq ptlst (cons (list (car intlst2) (cadr intlst2) (caddr intlst2))
  ptlst
      intlst2 (cdddr intlst2)
  ptlst
http://qjchen.mjtd.com
My blog http://chenqj.blogspot.com (Chinese, can be translate into English)
