Author Topic: No command prompt after background (VBA) call  (Read 2471 times)
msasu
  • Mosquito
« on: April 23, 2010, 07:10:09 AM »
It is possible to control the visibility (show / hide) of command line trough VBA code?
I’m calling AutoCAD via ActiveX technology from a stand-alone Visual Basic application and perform some drawing operations while keeping the AutoCAD window hidden; the issue is that each time you start AutoCAD after that the command line is hidden and should use <Ctrl>+9 to restore it. Is there a solution to fix that by code before discarding the AutoCAD object? Thank you.
Regards,
