Author Topic: SSGET - 2 lines different starting point  (Read 1879 times)
debgun
« on: March 04, 2010, 02:42:24 PM »
I'm trying to select the two lines that I've created.  I'm trying to select them based on their starting points, but I'm not having much luck.
(defun AddLines ()
  (setq adoc (vla-get-activedocument (vlax-get-acad-object))
acsp (if (zerop (vla-get-activespace adoc))
(if (=(vla-get-mspace adoc) :vlax-true)
  (vla-get-modelspace adoc)
  (vla-get-paperspace adoc)
(vla-get-modelspace adoc))
  (vla-addline acsp ;add li line to relay output module
    (vlax-3d-point (list 2.96 9 0))
    (vlax-3d-point (list 2 9 0))
  ) ;vla-addline
  (vla-addline acsp ;add out line to relay output module
    (vlax-3d-point (list 5.04 8.8 0))
    (vlax-3d-point (list 6 8.8 0))
  ) ;vla-addline
  (command ".Regen")
  (setq ss (ssget "X" '((0 . "LINE")
(-4 . "<OR") (10 2.96 9.0 0.0) (10 5.04 8.8 0.0) (-4 . "OR>"))
  ) ;setq
  (setq en (ssname ss 0))
    (setq obj (vlax-ename->vla-object en)
  numrows 16
  numcol 1
  numlevels 1
  rowspace -0.4
  colspace 0
  distbetlevels 0
     ) ;setq
    (setq arrobj (vla-arrayrectangular obj numrows numcol numlevels rowspace colspace distbetlevels)
  objlst (vlax-safearray->list (vlax-variant-value arrobj))
    ) ;setq
 ) ;defun
Re: SSGET - 2 lines different starting point
« Reply #1 on: March 04, 2010, 02:49:25 PM »
Deb,
vla-AddLine will return the Line Object that was created (if successful), so no need to collect them up  :-)
alanjt
  • Standby for witty remark...
« Reply #2 on: March 04, 2010, 02:50:39 PM »
Why not just setq (vla-addline?
Edit: Sneaked it in under me Lee.
Dropbox
alanjt
« Reply #3 on: March 04, 2010, 02:53:07 PM »
BTW, Debgun, you don't have to call Regen with the command.
(vla-Regen adoc acActiveViewport)
Dropbox
debgun
« Reply #4 on: March 04, 2010, 03:08:39 PM »
WOW!  Thanks, guys!  I seem to make a anthill into a molehill all the time.
« Reply #5 on: March 04, 2010, 03:10:51 PM »
No worries Deb, we've all been there  :-)
