Author Topic: problems with dcl files in ACAD2010  (Read 1498 times)
Amsterdammed
« on: February 18, 2010, 08:15:36 AM »
Hello there,
i got the request of some colleagues to get an old program running in 2010 again. It seems that the base.dcl file is gone now and i get some errors because of that. Is that a known fact?
Thanks in advance
bernd
Re: problems with dcl files in ACAD2010
« Reply #1 on: February 18, 2010, 08:40:27 AM »
<..> It seems that the base.dcl file is gone now and i get some errors because of that. Is that a known fact?
No.
this is a search result on my machine
Amsterdammed
« Reply #2 on: February 18, 2010, 10:23:02 AM »
Kerry,
thanks, i forgot that the stuff is not in support anymore.....
And the program i need to get running is looking for it in support, too; so that was an easy fix! :-)
Bernd
