Author Topic: Merging Layers with LAYMRG  (Read 2764 times)
Willie
  • Going nowhere slowly
« on: February 08, 2010, 08:18:20 PM »
I merged some layers to get all of my profile band text on one layer.  It worked, but it didn't change the properties of the band style to the new layer.  It changed it to AcDbObjectId::kNull.
I had to change the properties manually of each band style.
Soli Deo Gloria | Qui Audet Adipiscitur
Windows 8  64-bit Enterprise | Civil 3D 2015 and 2016| ArcGIS 10.1
Yogi Berra : "I'd give my right arm to be ambidextrous."
Willie
Re: Merging Layers with LAYMRG
« Reply #1 on: February 08, 2010, 08:19:04 PM »
Just thought I should share.  :-)
sinc
« Reply #2 on: February 08, 2010, 08:27:50 PM »
Well, I suppose that's nicer than crashing...   :-)
Willie
« Reply #3 on: February 08, 2010, 08:29:16 PM »
« Reply #4 on: February 08, 2010, 08:34:15 PM »
I would NOT have expected that changing the layer the Profile Band Text was on with a(n) autocad command would have any impact on a sub-item within a C3D object.
However; I do like the way you were thinking.   ;-)
as I say in class
"if you do not like the way something looks, or it's cad properties; then give it a NEW style!"
however the warning is filed away for future references
« Last Edit: February 08, 2010, 08:39:17 PM by mjfarrell »
