Author Topic: Convert from .dll to .exe  (Read 2750 times)
BillZndl
« on: January 26, 2010, 03:02:01 PM »
I have a small assembly (.dll) that displays a listview created from the contents of an excel file.
I really don't need AutoCAD for this and was wondering is there an easy way to compile it to an .exe windows form stand alone.
The only place that I reference AutoCAD is in the command method section:
using System;
using System.Windows.Forms;
public class Initialization : Autodesk.AutoCAD.Runtime.IExtensionApplication
    public void Initialize()
        Editor ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
        ed.WriteMessage(" OBMSRef --- Loaded\r");
    public void Terminate()
namespace OBMSRef
    /// <summary>
    /// Summary description for main class.
    /// </summary>
    public class PartMonitor1
        [CommandMethod("OBMSRef")]
        public static void ShowModelessDialog()
            Autodesk.AutoCAD.ApplicationServices.Application.ShowModelessDialog(OBMSRef.Instance);
The form section only references the system:
using System;
using System.Text;
using System.IO;
using System.Collections;
using System.Globalization;
namespace OBMSRef
    /// <summary>
    /// Summary description for PartMonitor.
    /// </summary>
    public class OBMSRef : System.Windows.Forms.Form
        private System.ComponentModel.Container components = null;
        private Button button2;
        private RichTextBox OldNumSearch;
        private ImageList ImgLst = new ImageList();
        private Button button1;
        private RichTextBox OBMSSearch;
        private ListView listView1;
        private Button button3;
        private ColumnHeader OBMSNumber;
        private ColumnHeader AS400Number;
        private ColumnHeader Description;
        private Label label1;
        private static OBMSRef instance = null;
        public static OBMSRef Instance
            get
                if (instance == null)
                    instance = new OBMSRef();
                return instance;
        /// <summary>
        /// Required designer variable.
        /// </summary>
        public OBMSRef()
            // Required for Windows Form Designer support
            InitializeComponent();
            // TODO: Add any constructor code after InitializeComponent call
        /// <summary>
        /// Clean up any resources being used.
        /// </summary>
        protected override void Dispose(bool disposing)
            if (disposing)
                if (components != null)
                    components.Dispose();
            base.Dispose(disposing);
        #region Windows Form Designer generated code
        #endregion
        [STAThread]
        static void Main(string[] args)
            System.Windows.Forms.Application.Run(new OBMSRef());
        #region all form overrides
        /// <summary>
        /// </summary>
        /// <param name="e"></param>
        protected override void OnClosing(CancelEventArgs e)
            base.OnClosing(e);
            e.Cancel = true;
            Visible = false;
        protected override void OnShown(EventArgs e)
            base.OnShown(e);
            FillListView();
        #endregion
        #region All form Buttons section
        /// <summary>
        /// Button section
        /// </summary>
        /// <param name="sender"></param>
        private void button1_Click(object sender, EventArgs e)
            try
                SearchForOBMS();
            catch (Exception ex)
                MessageBox.Show("SearchOBMS: " + ex.StackTrace);
        private void button2_Click(object sender, EventArgs e)
            try
                SearchForPart();
                MessageBox.Show("SearchPart: " + ex.StackTrace);
        private void button3_Click(object sender, System.EventArgs e)  //Exit button
            Hide();
        #endregion
        public void SearchForOBMS()
            try
                string obmsNum = OBMSSearch.Text;
                ListViewItem item = listView1.FindItemWithText(obmsNum, true, 0, false);
                if (item != null)
                    listView1.Items[item.Index].EnsureVisible();
                    listView1.Items[item.Index].Selected = true;
                    OBMSSearch.Text = item.SubItems[0].Text;
                    OldNumSearch.Text = item.SubItems[1].Text;
                    label1.Text = "";
                else
                    OldNumSearch.Text = "";
                    label1.Text = "Not Found: ";
            catch (System.Exception ex)
                MessageBox.Show("SearchForOBMS failed: " + ex.StackTrace);
        public void SearchForPart()
            try
                string partNum = OldNumSearch.Text;
                ListViewItem item = listView1.FindItemWithText(partNum, true, 0, false);
                if (item != null)
                    label1.Text = "";
                else
                    OBMSSearch.Text = "";
                MessageBox.Show("SearchForPart failed: " + ex.StackTrace);
        public void FillListView()
            try
                GetXLFileList gxl = new GetXLFileList();
                List<string> strings = gxl.ListXLFile();
                string str;
                int indx;
                listView1.BeginUpdate();
                listView1.Items.Clear();
                for (int x = 0; x < strings.Count; x++)
                    ListViewItem item = new ListViewItem();
                    str = strings[x];
                    item.Text = str.Substring(0, 7);
                    str = str.Substring(8);
                    indx = str.IndexOf(" ", 0);
                    item.SubItems.Add(str.Substring(0, indx));
                    str = str.Substring(indx);
                    item.SubItems.Add(str);
                    listView1.Items.Add(item);
                listView1.EndUpdate();
                listView1.Refresh();
                MessageBox.Show("FillListView failed: " + ex.StackTrace);
        private void OldNumSearch_KeyDown(object sender, KeyEventArgs e)
            if (e.KeyCode == Keys.Enter)
                SearchForPart();
        private void OBMSSearch_KeyDown(object sender, KeyEventArgs e)
                SearchForOBMS();
Re: Convert from .dll to .exe
« Reply #1 on: January 26, 2010, 03:43:38 PM »
Yep,
Just build a new WindowsFormsApplication Project
Copy the Form.cs and Form.Designer.cs to the Project Folder
Add them to the Project in the Solution Explorer
Check the References
Compile.
BillZndl
« Reply #2 on: January 26, 2010, 04:35:00 PM »
Worked great!
Thank you Kerry!
« Reply #3 on: January 26, 2010, 11:10:18 PM »
Glad I could be of help Bill.
