Author Topic: test for object type by Is or casting...  (Read 9692 times)
Bryco
Re: test for object type by Is or casting...
« Reply #15 on: December 19, 2009, 02:48:51 PM »
sinc it seems to me that it is too much work to just compare the ObjectClass directly in a loop, although the predimmed version is the fastest.
Glenn I can't seem to find where the direct cast is always faster, the results seem to be very close.
« Reply #16 on: December 19, 2009, 06:25:30 PM »
interesting results Bryce.
Thanks.
« Reply #17 on: December 19, 2009, 06:29:08 PM »
So, at the risk of stating the obvious ;
"It depends"
on
whats is your data
what do you want to do with it
what percentage of the data do you want to do stuff to.
what mood you're in
Glenn R
« Reply #18 on: December 20, 2009, 08:44:26 AM »
D. All of the above.
Bryco
« Reply #19 on: December 20, 2009, 01:12:34 PM »
Sorry guys I messed this up.
below is a similar test but using a selectionset
            iplines = 0;
            start = DateTime.Now.Ticks;
            RXClass plineClass = RXClass.GetClass(typeof(Polyline));
            for (int i = 0; i < 10000; i++)
                foreach (ObjectId id in ids)
                    if (id.ObjectClass == plineClass)
                            pl = (Polyline)tr.GetObject(id, OpenMode.ForRead);
                            tr.Commit();
                            iplines++;
            ed.WriteMessage("\ndirect cast using pre dimmed class, ellapsed time ="
                + ((DateTime.Now.Ticks - start) / 1000).ToString()
                + " plines=" + iplines);
results
Select objects:
As test ellapsed time =25160 plines=30000
Field, ellapsed time =8340 plines=30000
direct cast using pre dimmed class, ellapsed time =8780 plines=30000
As cast using pre dimmed class, ellapsed time =8580 plines=30000
direct cast using id string comparison, ellapsed time =8940 plines=30000
Bryco
« Reply #20 on: December 20, 2009, 01:24:34 PM »
I had to test before making a transaction to make it a fair test.
In this test 3 of the 10 entities were plines
So I would have to say always use the objectid method.
The field was this
public RXClass rxPolyline = RXClass.GetClass(typeof(Polyline));
and it seems to work out ok but fields are too hard to use projectwide for me, as remembering where they are is too much work.
Still, after starting w/ objectid method I have to go with Kerry's
what mood you're in
« Reply #21 on: December 21, 2009, 12:50:12 AM »
Bryce,
Just a matter of interest
What is your ids collection ??
did you make an array from the Selection Set ?
        ObjectId[] idArray;
        idArray = SS.GetObjectIds();
        foreach (ObjectId id in idArray)
Bryco
« Reply #22 on: December 21, 2009, 09:51:35 AM »
I used an  ObjectIdCollection to gather the sel. set ids which is slower than what you have, but it is all before the timer starts.
jmaeding
« Reply #23 on: December 21, 2009, 12:38:32 PM »
Thx for all replies so far.
I should mention in my case, I am not only looking at acad objects.
James Maeding
« Reply #24 on: December 21, 2009, 04:29:06 PM »
I don't see that there would be a difference
... have you tried it ?
« Reply #25 on: December 22, 2009, 10:30:29 PM »
blatant bump attempting to get a response ....
jmaeding
« Reply #26 on: December 24, 2009, 01:55:46 PM »
right, no difference, but I cannot use ARXclass method wich seems to be pretty fast.
James Maeding
« Reply #27 on: December 25, 2009, 07:20:16 PM »
Care to explain why you can't use it ??
What are you ACTUALLY trying to do ??
