Author Topic: How can I get the DWG file is created by which template?  (Read 1553 times)
guohq
« on: December 07, 2009, 01:10:40 AM »
You'll select a template when you create a new dwg file. How can I get the DWG file is created by which template if the dwg file  exists?
cadabyss
Re: How can I get the DWG file is created by which template?
« Reply #1 on: December 07, 2009, 07:28:16 AM »
You can only determine which template was used to create an existing drawing if the template contains a unique identifier stored inside it, such as a user variable, a dictionary entry, or whatever.  As installed, AutoCAD does not come with a unique identifiers in the templates.  You would have to create them first.
