That's right, if I remember correctly lisp prints the result of the last function to the command line, how do I get it to send it to the command line once calculated but before it resets the modes??
Like this?
;; Imperial string to mm converter
(defun c:IMP()
;save the currnet polar mode [if used we can set it back]
(setq polmode (getvar "polarmode"))
;set orthomode on
(setvar "orthomode" 1)
(setq ds (getstring t "\nEnter Imperial Distance: "))
(setq value (cvunit (distof ds 4) "inch" "mm"))
;this is where it falls down -
(setvar "orthomode" 0)
(setvar "polarmode" polmode)
value
