Author Topic: Get Selected Layouts  (Read 3139 times)
« on: July 30, 2009, 07:28:29 PM »
This is a question posted on another forum I am a member of, and it has stumped me, so I thought I'd see if you guys knew something  :-)
How can one retrieve a list of the selected layouts in a drawing?
i.e. if the user has ctrl-clicked on multiple layout tabs, how does one get a list of those selected?
Thanks,
Lee
It's Alive!
  • Retired
  • AKA Daniel
Re: Get Selected Layouts
« Reply #1 on: July 30, 2009, 09:31:31 PM »
I think in Arx, one might use  bool getTabSelected() const; , I did not see a way to do this with lisp
« Reply #2 on: July 30, 2009, 10:14:02 PM »
(setq layout (dos_multilist "Select Layouts" "Select layouts" (layoutlist)))
It's Alive!
  • Retired
  • AKA Daniel
« Reply #3 on: July 30, 2009, 11:46:03 PM »
Well since you're learning C++/Arx, here is a sample for you. (attached ARX for 2007)
the function is (crpselectedlayouts)
static int ads_crpselectedlayouts(void)
  // this is our "list" we will return to lisp.
  // we need to keep a copy of the head of the list
  // and add to the tail.
  struct resbuf *pRbHead = acutNewRb(RTLB);
  struct resbuf *pRbTail = pRbHead;
  // get the database.
  AcDbDatabase *pDb = acdbHostApplicationServices()->workingDatabase();
  // open the layout dictionary.
  // a smart pointer will manage our pointer for us.
  AcDbDictionaryPointer pLayouts(pDb->layoutDictionaryId(),AcDb::kForRead);
  // create a new iterator.
  // we need to delete this or LEAK!!!
  AcDbDictionaryIterator *pDictIt = pLayouts->newIterator();
  //iterate the dictionary looking for layouts that are selected
  for(;!pDictIt->done();pDictIt->next())
   // another smart pointer.
   AcDbObjectPointer<AcDbLayout> pLayout(pDictIt->objectId(),AcDb::kForRead);
   // if it's selected add it to our resbuf (list).
   if(pLayout->getTabSelected())
    TCHAR *pszLayoutName;
    // the Arx docs say do not free pszLayoutName.
    pLayout->getLayoutName(pszLayoutName);
    // add new to the end of the list.
    pRbTail = pRbTail->rbnext = acutBuildList(RTSTR,pszLayoutName,0);
  // return the list to lisp, AutoCAD will make a copy.
  // so we will need to free the memory or LEAK!!!
  acedRetList(pRbHead->rbnext);
  //clean up our iterator
  delete pDictIt;
  // free up the list
  if(pRbHead != NULL)
   acutRelRb(pRbHead);
   pRbHead = NULL;
  return (RSRSLT) ;
« Reply #4 on: July 31, 2009, 01:27:55 AM »
Another method for lisp.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #5 on: July 31, 2009, 01:41:43 AM »
« Reply #6 on: July 31, 2009, 06:35:27 AM »
Thanks for your replies guys.
I thought that this might be a task beyond the immediate capabilities of LISP - nice solution Alan, that would be a good work-around.
> Daniel,
Thanks for your reply, yes, I am learning C++, but I only started learning about 2 days ago :P  I have no idea how your code works... I think it will take some time for me to get to your standard...
Thanks,
Lee
