Author Topic: dynAmIc BlOcKs  (Read 3434 times)
laison
dynAmIc BlOcKs
« on: June 30, 2009, 10:50:03 PM »
I just started looked at dynamic blocks. Yeah, I am behind the curve. Well I curious if a 3D block could be modified into a dynamic block? All of the dynamic blocks that I see are 2D.
The thing is I do not know anyone that works in 2D and I haven't worked in 2D in years. I am not knocking it, it's just that well I thought everyone went to 3D years ago.
Matt__W
  • I like my water diluted.
Re: dynAmIc BlOcKs
« Reply #1 on: July 01, 2009, 08:20:14 AM »
So far, only 2D is supported (unless something has changed in 2010 - which I don't have installed).
Autodesk Expert Elite
James Cannon
Re: dynAmIc BlOcKs
« Reply #2 on: July 01, 2009, 08:27:47 AM »
You can make a dynamic block using 3D objects but not all actions will work.  You cannot stretch them, for instance, but an array will work as it's just copying the objects with a base point.
The thing that sucks is that, unless something has changed, you can't 3dorbit in the block editor or have actions work in any plane other than XY
Shinyhead
Re: dynAmIc BlOcKs
« Reply #3 on: July 01, 2009, 10:12:41 AM »
yup, I have seen some neat 3d DB's using 3d polymesh faces, but they could only be modified in 2 of 3 planes.
