Author Topic: Strange MultiLeader  (Read 1551 times)
Marc'Antonio Alessi
  • Marco
Strange MultiLeader
« on: November 30, 2022, 12:59:45 PM »
Open DWG > the ML is selectable…
Rigen   Command: Regen > the ML NOT is selectable…
it also happens to change some settings of the layers
NOT happens if PDMODE is 0 or 1   :tickedoff:
Re: Strange MultiLeader
« Reply #1 on: November 30, 2022, 04:49:07 PM »
Rigen? It works for me on 2023.
MSTG007
« Reply #2 on: November 30, 2022, 04:58:17 PM »
Same for me... Seems like its selectable and editable with the attribute.
Civil3D 2020
Marc'Antonio Alessi
  • Marco
« Reply #3 on: November 30, 2022, 11:19:14 PM »
Sorry,  Regen.    Rigen is in Italian ...
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: December 01, 2022, 12:40:02 AM »
I learned something new today :-)
Marc'Antonio Alessi
  • Marco
« Reply #5 on: December 01, 2022, 03:19:28 AM »
AutoCAD 2023 need 2 command Regen
AutoCAD 2019 need 1 command Regen
AutoCAD 2013 need 1 command Regen
BricsCAD no problem
The Multileader IS always selectable by Point inside (X), if I move the ML by point inside it it becomes selectable again.
Sorry for my english  :whistling:
Marc'Antonio Alessi
  • Marco
« Reply #6 on: December 01, 2022, 03:21:37 AM »
Si, prova a guardare la GIF che ho inviato…  :-)
Marc'Antonio Alessi
  • Marco
« Reply #7 on: December 02, 2022, 02:43:57 AM »
I'd like to at least know if anyone had the same behavior  :?
It's Alive!
  • Retired
  • AKA Daniel
« Reply #8 on: December 02, 2022, 03:37:40 AM »
I see what you mean, if I regen, it’s hard to select, you can’t run (entget(car(entsel))) on the leader section either… only the X
It's Alive!
  • Retired
  • AKA Daniel
« Reply #9 on: December 02, 2022, 03:45:37 AM »
If I drag it around by the X, the leader becomes select-able again..... but then it goes away once you regen again
It's Alive!
  • Retired
  • AKA Daniel
« Reply #10 on: December 02, 2022, 03:53:44 AM »
even if I add arrows, the grips don't show... wondering how this was created?
Marc'Antonio Alessi
  • Marco
« Reply #11 on: December 02, 2022, 06:29:29 AM »
it was done with AutoCAD commands... including the MultiLeader style…   :knuppel2:
For the moment I have solved with PDMDE 0, I have to try if removing the POINT resolves it (out of curiosity, because I need the POINT)
Grazie  :-)
Marc'Antonio Alessi
  • Marco
« Reply #12 on: December 02, 2022, 01:22:48 PM »
Grazie  :-)
I checked: it's the POINT inside the block that creates this problem  :x :idiot2: :roll:
